Jan-11-2020 10:06 AM
Jan-15-2020 04:31 PM
Crushedstang50 wrote:
with it can't I just bypass my stock converter/charger.
Jan-12-2020 02:37 PM
Jan-12-2020 10:58 AM
Jan-12-2020 10:52 AM
BFL13 wrote:
I posted this yesterday, but people must have missed it. The pdf manual is linked in this, scroll down. Do what it says.
https://ultimatepower.com/products/inverter-chargers/pcul-series/3000w-pure-sine-inverter-charger-pc...
While in the Standby (charging) Mode, the AC input is continually monitored. Whenever AC power falls below the Trip voltage, the inverter automatically transfers back to the Invert Mode with minimum interruption to your appliances - as long as the inverter is turned on. The transfer from Standby mode to Inverter mode occurs in approximately 10 milliseconds. And it is the same time from Inverter mode to Standby mode.
Jan-12-2020 10:40 AM
Jan-12-2020 10:26 AM
Jan-12-2020 09:07 AM
Amateur Radio K3EXU
Jan-11-2020 01:35 PM
Jan-11-2020 01:33 PM
SoundGuy wrote:It's an inverter/charger.
At times when you're not using the inverter just turn the converter back on again.
Jan-11-2020 12:46 PM
Yes my plan was to just disconnect the stock coverter/charger.
If that would work how big of 120v cable do you think would be safe? To and from the inverter/charger.
Jan-11-2020 11:59 AM
Jan-11-2020 11:29 AM
Hello all!
My question is... with it can't I just bypass my stock converter/charger.
Jan-11-2020 11:02 AM
