โMay-15-2018 04:43 PM
โMay-20-2018 01:34 PM
โMay-19-2018 07:04 PM
โMay-17-2018 12:53 PM
Joe417 wrote:
I had that happen on a prowler 5th W.
It had 1/2" pipe about 4" long mounted horizontally like rollers on the outside edge of the camper to support the slide as it rolled out. There were 4 of them. They were literally a roughly cut piece of pipe slid on a 1/4" x 6" bolt mount between 2 "L" brackets.
The fiberglass obviously wasn't bonded well enough to withstand the weight of the slide on the "rollers". It eventually made cracks in the fiberglass.
I ended up replacing the whole slide floor but not because of the cracks. While doing that I re-worked the rollers and bolts so they rolled easier. Used a smaller pipe on 3/8" bolts and rounded the edges. I didn't put fiberglass back on the bottom of the slide I used a woven black plastic material that is used on the bottom of some brands of campers.
Worked great the rest of the time we had it.
Our '01 Jayco which we bought new and still works great, has a solid plastic (probably nylon) support about 3" wide and the full length of the 12' slide. Much better than the rollers.
โMay-16-2018 08:26 PM
โMay-15-2018 05:38 PM
