Underperforming Dometic Fridge...
Wankel7
My 3 year old Dometic RM2551 (5 Cubic foot model) isn't cooling well enough on propane. Unable to test in AC. Creeps up to 50f inside ...90F outside. Running an internal and external DC fan. Cleaned the orifice and burner tube. Flame looks great and the camper is level. Side vent and roof vent clear.
When I turned it on the first day after 5 months of storage it was 32F inside for 24 hours. Then it started slipping to 50F.
Ohm checked the thermistor and it passed.
I am stumped.
Picture of the flame.
https://1drv.ms/u/s!AoCNkn5aOOMYwyGUMDKRnORL7Tu6
14 REPLIES 14
Wankel7
Old-Biscuit wrote:
When overheated (lack of airflow/ventilation, interruption of gravity flow etc) the sodium chromate crystallizes and plates out on the inside of tubes.
The crystals accumulate....causing more interruption of gravity flow....more overheating...more crystals
And they are permanent
I agree....
It is going in the trash....picking up a DC compressor fridge tomorrow ๐Ÿ™‚
https://www.coastalclimatecontrol.com/index.php/refrigeration/vitrifrigo.html#!/Vitrifrigo-C115-under-counter-Fridge-w-freezer-Black/p/95699165
Wankel7
doxiemom11 wrote:
We were having the same problem with our frig - 90 and that side of the rv was in the sun in the morning. Added the dc exterior fan AND finally pulled out main awning out (has been windy) and no more problem.
When you say same issue you had a freezer that was very cold and fridge that was warm?
I have both an internal and external fan.
Chris_Bryant
You cannot diagnose a cooling unit problem running on lp, there are too many variables. Everything else will run happily on a 9.5" wc pressure. Test it on 120 volt power, check the lp pressure at the burner.
-- Chris Bryant
doxiemom11
Old-Biscuit
Wankel7
Old-Biscuit wrote:
Wankel7 wrote:
2oldman wrote:
Any yellow or green powder on the coils?
That is a great idea. I read about the limp mode when the thermomister is unplugged. I will do that !
The tubing that runs up the fridge backside is black with dust.
I used my temp gun and get 0F to -4F in the freezer. What is normal for the freezer ? Temp gun shows around 50F on the fins in the fridge.
The thermomister is on the furthest right fin middle of the fin. The clamp makes it difficult to put on any other fin.
Temp guns are not the best method to measure fridge temps with but 0*F/-4*F is perfect temps for freezer
50*F on food compartment fins is NOT good.....cooling unit has blockage between freezer and food compartment
With that cold of freezer temps food compartment should be 38*F
Have you been running fridge 'off level'?????
Force cool it with thermistor unplugged BUT doubt if you will see improvement in food compartment temps
Fin temps should be 10*F lower then food compartment temps measured with a bulb thermometer in glass of water sitting on shelf
Good point. Something is stopping the fridge fins from getting cooled.
The trailer sat nose up all winter. It was cold at times. -15F. I leveled it for two weeks then fired up the fridge while level.
Is a blockage like a blood clot? If it passes it will get caught again?
nineoaks2004
check the LP system with a manometer, you should get 11" water column, from the last place on the line, if not then you can adjust the regulator so you get the 11". This just happened to me and the problem is corrected.
By the time you learn the rules of life
You're to old to play the game
Thunder_Mountai
If you can't find an easy/cheap fix, I suggest you think about a residential refrigerator unless you dry camp extensively. When our evaporation frig in our old MH started doing what you describe, we yanked it out. It was cheaper to go with the residential than trying to repair the old one.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
Old-Biscuit
jodeb720
i had a similar problem with my fridge. Turns out the baffle in the flue had rusted and wasn't transferring the heat properly.
If Limp mode doesn't fix the problem (or even if it does) check the baffle in the flue (you have to pull it out from the top of the fridge).
2oldman
There shouldn't be any dust on the coils, except maybe for plain old road dirt. Post a picture.
Wankel7
2oldman
Old-Biscuit
The flame looks good...Blue and reaching just up into the bottom of flue center.
Need to check thermistor/temp controls by unplugging thermistor from lower circuit board and let fridge run for 12 hrs.
Fridge should run continuously and dang near freeze items in food compartment
Thermistor leads plug into P2 2 pin connector on left upper area
If fridge cools down with thermistor unplugged then replace thermistor
(even though it Ohm OK)
IF fridge does not cool down then you have a ventilation, airflow/draft or bad cooling unit problem
What FIN do you have thermistor on and where on fin is it?
