โJan-20-2017 09:54 AM
โFeb-25-2017 05:43 AM
โFeb-24-2017 07:46 PM
โJan-25-2017 01:48 AM
LarryJM wrote:Chris Bryant wrote:
yes- red and black tied together, but.... that 50 amp plug is nothing special to RVs- it's a commonly used one.
YEP and while LOWE's is not an option I assume they carry a 50A pigtail for wiring in things like 220V dryers and ranges. You might find something similar there in Mexico at somewhere that deals in appliances and even might get one from a junk yard and then with a junction box you can splice in your existing cord to the new pigtail with the newer 50A plug.
Larry
โJan-24-2017 11:44 PM
โJan-24-2017 06:46 PM
โJan-24-2017 05:54 PM
time2roll wrote:
Yes separate branch circuits but are they on separate MAIN breakers to spread the load across both sides of the plug?
โJan-22-2017 11:06 AM
MrWizard wrote:
Acorn nut
Proper name "split bolt" aka Kernie
I usually have a few in the electrical too bag
โJan-22-2017 10:57 AM
โJan-22-2017 10:54 AM
time2roll wrote:
Seen far worse posted along the way. Not sure I would be too concerned as shown.
Did you check if both heat pumps are on one side? Can you get by with just one?
โJan-22-2017 10:26 AM
โJan-22-2017 09:04 AM
โJan-22-2017 08:38 AM
โJan-21-2017 04:29 PM
โJan-21-2017 02:22 PM
