Update Trouble of the Worst Kind.Black Tank Won't Empty Help
allen8106
For the latest see page 3 of this thread.Ok all you camper experts out there I need your help in the worst way. I have a 2010 Jayco 31.5 RLDS that I bought new in March 2011. We have used it profusely since we bought it as you can tell by my sig without any issues other than a couple propane pigtails that malfunctioned. On Thursday October 30th we went to the lake, there was no fresh water available because the water had been turned off for the winter. No problemโ€ฆI had recently sanitized my fresh water tank so we found a spigot with water and filled up the on board tank and stayed through Sunday. At the last minute we decided to leave the camper and come back the following week. My wife went back out Wednesday and I went back out Thursday after returning from work related travel. We stayed until today using the on board fresh water tank the whole time so roughly 7-8 days total. When we left the park today I knew there was no water at the dump stations to rinse the tanks with but figured I could rinse out at home since we live in the country and I have three clean outs between the house and the lagoon. When I dumped I could tell the black tank did not empty completely. I confirmed this by shining a light down the toilet. It looked like it was about ยพ full yet nothing would come out of the dump pipe. I went to a water spigot and added more water and tried to dump again. No goโ€ฆ..No problem me thinks, Iโ€™ll dump at home where I can hook a water hose to the rinse fitting. So I drive 30 miles home with a full black tank pull the camper up to the clean out and proceed to dump/rinse like I would at the lake. Againโ€ฆnothing would come out. I unhooked the water hose from the rinse fitting and stuffed it at least 6-8 feet into the dump pipe and still couldnโ€™t get anything to come out. I thought maybe the valve wasnโ€™t opening so I pushed the valve closed and stuffed the hose into the pipe until it hit the valve, opened the valve and the hose went about 2-3 feet further. I would think this is telling me the valve is opening like it should but I still canโ€™t get anything to come out other than the fresh water I am putting up the dump pipe with the hose. When you shine a light into the toilet you can see the sewage so I know itโ€™s there. Itโ€™s still about ยพ full with plenty of water but for the life of me I canโ€™t get it to drain. I even pushed and hand held drain snake up the pipe about ten feet and still canโ€™t get it to drain. I pulled the underbelly cover off to see if the valve was opening. It appears that it is so Iโ€™m stumped.
By the way...As a side note our 23 year old daughter stayed with us most of those days. I don't think she would put anything she shouldn't in the toilet but I haven't had a chance to ask her yet. My wife assures me she hasn't put anything in it she shouldn't
Any suggestions from you experts?
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
38 REPLIES 38
allen8106
myredracer wrote:
Sometimes the disc from cutting out the opening for the 3" pipe can be left in the tank and will plug the outlet. Who knows, since you've had the TT for a few years, maybe "someone" put something into the tank they shouldn't have.
>I had considered this also based on a previous post.I had considered this also based on a previous post.
After having an in-tank flusher, I have found that it works much better than a back-flush elbow, but you want to use it to clean your tank (when dumping at the CG) to get the tank clean before you head home. I only use our elbow now to watch what's coming out (and to provide an angled transition).
>I use the in tank flusher religiously after each camp session.
The solution is prevention. Add 4 or 5 gallons before you use the tank, use lots of water when flushing #2, and fill the tank up before you open the valve. Resist the temptation to skimp on water to extend the time before you need to dump the tank.
>This is something I didn't do. Might be my downfall.
You might try getting a stiff, hard-walled garden hose and pushing it up into the tank and down into the tank to try and break up the solids and clear it. A plumbing snake might work in through the outlet.
>Tried the plumbing snake, no go. Tried a hose pushed up the drain pipe, no go.
If all else fails, you can use liquid drano. Our owner's manual actually says to use it if needed and we did use it once. It MUST be the version that does not attack metal and DO NOT ever dump it into an on-site septic disposal system or you can permanently damage it. If you use this, you'd want to tow your TT around a bit to slosh the contents around inside the tank. Your tank will end up clean as a whistle.
>Might need to try this. I have a wand I can stick down in the tank that has a 90 degree pointed outlet spout that I am hoping I can use to break it all up so it will drain.
>I also wonder if the Flush King as suggested in previous posts will even be that effective. The drain pipe goes from the side of the camper to the back side of the black tank, takes a 90 degree turn then hits the valve then goes into the tank. My local RV dealer claims the 90 degree elbow at the entrance to the tank renders the Flush King pretty well useless and he even had on in stock I was prepared to buy until he talked me out of. If all else fails I still might try it.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
PaulJ2
After you get this solved---Every time before use I put in 1-2 cups laundry detergent and about a gallon of water. It keeps the inside slippery and slimey and nothing sticks to it when dumping.
beemerphile1
allen8106 wrote:
...our 23 year old daughter stayed with us most of those days. I don't think she would put anything she shouldn't in the toilet but I haven't had a chance to ask her yet....
Betcha I know what caused the blockage, it wasn't toilet paper or poo! It is another paper product that swells in contact with water.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Pipeman
A number of years back I had a similar situation. Twice. I ended up using the wand that goes down the toilet but I used my air compressor to break things up because when using the wand with water the tank and toilet would fill up with water. Using air is not fun either but it eventually worked. You may want to try to get a hold of a few bottles of RV Digest by Unique. Put a whole bottle into the tank and let sit for 24 hours. If I read right it will dissolve the hard stuff in that time. I use it in my 5er and it seems to do what it says. RV-Digesthere
Pipeman
Ontario, Canada
Full Member
35 year Fire Fighter(retired)
VE3PJF
John_Joey
I know I'm stating the obvious, but there can only be two things either the valve is stuck closed, or you have a blockage.
Everything you did should have fixed the problem which means you either assuming/overlooking something, or not snaking it good enough.
Since you seem to be OK with snaking from the dumping area, I would buy about 10 feet of stiff PEX type tubing. Plumb a hose connection (with shut off) to one end of that tubing, connect the hose to it, open the valve, run the tubing up the line until you hit something, turn on the water and stand back. If you want a little safety, buy an end cap with a hose connection and run the tubing through that hose connection. That way when it give way you only have a 3/4 inch opening to deal with instead of a 4 inch one.
Good luck.
Thereโ€™s no fool, like an old fool.
myredracer
The solution is prevention. Add 4 or 5 gallons before you use the tank, use lots of water when flushing #2, and fill the tank up before you open the valve. Resist the temptation to skimp on water to extend the time before you need to dump the tank. If you delay cleaning it properly after each camping trip, you can make emptying and cleaning a real problem down the road. Again, you want to make sure it's thoroughly cleaned before you head home.
We have had trouble in the past with extreme difficulty in emptying our black tank. Some tanks are simply harder to dump and clean due to their dimensions and configuration. Some tanks, like ours, are shallower and long and harder to drain. After opening the valve, I run the tank flusher for 5+ minutes (while breaking camp) then fill the tank up (with foot valve) and dump. Then I look down the toilet and if the tank bottom is not spotless, I repeat the rinse, fill and dump process again. Takes me 2, or maybe 3 repetitions to get the tank spotless. The tank in our first TT was a piece of cake to dump and we never ever had an issue.
I am of the opinion that using the correct type of TP helps so that it breaks down when in the tank. Some RV brands of TP actually do not break down as you would think they should. Some ordinary household brands do break down, like one of the Costco brands we use. You can put a few sheets of your TP in a glass of water and see if it disintegrates into small pieces after a few hours.
Good luck and report back when you get it figured out.
ps: It helps to avoid long run-on paragraphs (like in 1st post) when posting and break your point/thoughts up into smaller paragraphs. Gets hard to wade through looong paragraphs. ๐Ÿ˜‰
falconman
Might pay to have the tank suctioned via the toilet opening. Then you get a better look at the problem. There might be a septic tank company that could help you out.
allen8106
j-d wrote:
Is something FROZEN, as in ICE?
No ice, the coldest it got at the lake was 33F.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
RJsfishin wrote:
This didn't just happen, Sounds like it has been building up,.....maybe since new, draining off nothing but the water, while the solid was building up, and getting dryer all the time to where it is now a solid block. You need to just slowly break it up w/ a full flow water hose, from the bottom first, and if no good, do it from the top. One thing about it, if you are the normal, you'll get it, one way or another, and you'll never let it happen again.
I had it happen once in 45 yrs.
I've rinsed it with the tank flusher religiously because of the feedback I've read on here. I always rinse until it runs clear.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
Oaklevel wrote:
Probably too much poo & paper and not enough water...... They make a power wand flusher that attaches to the garden hose to give pressure that might help.
I have one, I'm, going to try it tonight after work.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
j-d
Joe417
I had a similar issue the first time we used our Jayco in Pigeon Forge in Jan 2002. You never forget those things.
I bought some 3/8" thick wall polyethylene pipe and could push it into the tank but the hole would fill back in when the pipe was removed and the tank would not drain. Only a few ounces each time. What an unpleasant mess, went on for two days.
1st **) The way I overcame the issue was to buy a Flush King, using water to push the clog backward and break it up. Was mostly toilet tissue that did break up but seamed to pack together. From that day on we flushed twice if tissue was used.
2nd **) Found the cause about 9 years later. Removed the tank to fix a leak, there was an extra large #3 Craftsmen screw driver stuck in the elbow of the pipe along with the round piece of plastic cut out for the tank vent. The larger round piece of plastic cut out for the tank drain was still in the tank.
I haven't done the math but the pipe is about 3". At approximately 9 sq. in. and 50 psi water pressure that should be over 400 lbs pushing on the clog. In addition, the sewer hose can be attached to the Flush King while your doing this which makes it much less messy.
The Flush King is worth every penny when you need it. I've only needed it the one time, but carry it in the Jayco at all times.
Good luck
Joe and Evelyn
MEXICOWANDERER
60C water sometimes works wonders
time2roll
Nothing comes out? Not even some liquid?
Are you sure when you pushed that hose 3' past the valve that was enough to get to the backside of the tank?
If you are brave enough to shove a running hose up the black drain you gotta go all the way until you see water movement from looking in the toilet.
I would be far more inclined to use a back flush fitting.
allen8106
SeaDog/BRR wrote:
When you left the unit for that week it may have had the poop crust up and make a seal across the tank. Take a pressure washer, try first with the toilet in place and the wand down into the poo if that doesn't work pull the toilet like someone else said and give that a try.
When I left the unit from Sundsy to Wednesday it had water in the tank along with the poo.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
