Used Solar Panel?
Gulfcoast
I need a used 100-watt 12-volt solar panel to charge a deep-cycle battery with. Anyone know where to buy one, or have one for sale?
I simply can't afford a new one at this time. Thanks
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
29 REPLIES 29
Gulfcoast
I changed out all the lights to the 13-watt energy efficient bulbs, that sure cuts the watts down.
RV'ing since 1960
Mega Cab
Gulfcoast
smkettner wrote:
So rent the cabin for the weekend. Price is a 100+ watt solar panel. Next guest can donate a controller. Third and subsequent can bring a new battery. ๐Ÿ˜‰
Good idea, but this little cabin does not belong to me, I am simply doing a friend a favor. Great idea though.
RV'ing since 1960
Mega Cab
MrWizard
Moderator
Moderator
... And panels are mismatched, and some are getting old (= reduced efficiency)
all the panels I bought used are UniSolar,
all have the same output voltage, they are different watts, aka different amps
but are 'electrically' compatible
and close enough to 'one pair' of the original panels to be compatible
the ODD pair of oem panels i rewired to the chassis/engine batteries
I can explain it to you.
1997 F53 Bounder 36s
time2roll
Almot
MrWizard wrote:
...but we full time, we cook with electric and we have a residential fridge,
and our lighting is Florescent
... And panels are mismatched, and some are getting old (= reduced efficiency). Whatever works for Mr. Wiz. With all-electrical cooking and fridge, and with 2 people, and with morning "marine layer" of fog in coastal Ca, it would take at least 900W solar to live without a generator. No, wait, they already have 900W... Or getting close? ๐Ÿ˜‰ ...
With propane fridge (not that I like it), and cooking on gas mostly, one person can live off 200-300W solar if he chooses to. Back to the OP question - 100W panel is way too little for fulltime living. Barely enough even for a seasonal summer cabin.
MrWizard
Moderator
Moderator
its NOT backup, its used power, and usually run a generator every day
started out with 4 6v GC's
addedd 4 12v AGM deep cycle server batteris
replaced the 4 GC's this summer with 3 12v's .. need one more 12v
so i have 7 batteries approx 900ampHrs worth
these conditions, DO NOT APPLY to Gulfcoast the OP
hershey
Gotta ask Mr Wizard.....what do you have for battery backup?
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
Gulfcoast
What a fine setup on the RV... and I want just one panel. smile
RV'ing since 1960
Mega Cab
Almot
hershey wrote:
I think if you do the math, in the long run, a small generator would end up being cheaper.
I don't think so. Compared to residential power rates, panel and controller pay for itself in about 10-15 years of everyday use. Depends on the size too. Bigger system costs less per watt and pays for itself sooner, but when it's too big, the user may chicken out and call in the contractors, and then labor costs are 2-3 times of the parts cost. So there are many variables.
But a generator is a negative entry in the book, no matter how you look at it. Initial costs of a decent gen set with charger are close to medium size solar parts cost, if not higher. And then there is cost of fuel and maintenance. The only scenario when generator has a chance to end up being cheaper than solar, is when you a) already have a genny, and b) camp offgrid very occasionally.
MrWizard
Moderator
Moderator
MEXICOWANDERER wrote:
A used solar panel would be about as hard to dispose of as a used 100 dollar bill. They don't get to see the light of day in a public forum unless a project renewal takes place and a dealer snaps them up in a lot sale.
"Damn, tighten it down wrong just a little and it don't do squat. Better sell this turkey. Standing up or laying flat, loose, it tests fine. Someone will buy it"
You have no guarantee you won't run into the same issue as one of my customers with his used panel. Of course the "sale" was made in a Denny's parking lot "for convenience". Then again you may end up with a good panel with just the slightest of ricochet scratches across it, and pigtail wires ready to solder to.
i got all my panels used over an 18 month period
buying them in separate lots
and testing each panel at time of purchase
click image for full size picture
second set.. being cleaned and prepped for mounting
[IMG]http://i298.photobucket.com/albums/mm251/Mr__Wizard/IMG_20120410_134355_1024x768.jpg" width=480...[IMG]http://i298.photobucket.com/albums/mm251/Mr__Wizard/IMG_20120410_134138_1024x768.jpg" width=480...
hershey
Gulfcoast wrote:
In the long run solar would be cheaper, but a gen can do the job with some daily fuel. It's interesting to experiment with anyway.
With a solar panel the real efficiency of it would be in the amount of amperage you can but in the bank (a battery) for around the clock usage.
You would need, I think, a bank of at least 4 6 volt batteries...thats $375 bucks. Even half that would buy probably all the fuel you will need for the generator.
MEXICOWANDERER
Gulfcoast
I'm sticking with a small generator for now... thanks for the info guys.
RV'ing since 1960
Mega Cab
doughere
You can get a new 100 watt panel delivered from solar blvd for $150. If you need a controller (not needed if you are going to be monitoring the system) for $15 on e-bay.
You can look on craig's list or e-bay, but I don't think you're going to do any better.
The price of panels has been dropping so fast, that I doubt you are going to find someone to sell a used one for less than that. A used 100 watt panel a few years old cost 200-300, most people would keep it, or not be willing to sell it for what its worth now.
Doug
