Consider spending the 20 bucks on an LED replacement (I use Eco-Leds about 17-19 bucks a pop) ... If the things perform as advertised... I won't live long enough to change them again.
Put one LED panel (Closeout table 50 cents) in my car for a dome light. VERY BRIGHT (2x at least the normal dome light) only issue is there is a low current through the lamp even with door closed so the LED panel glows softly all the time. (I could fix that.. but why)
I replaced a 10 watt landscape light with a LED panel. Same effect as car save no current when off. (These are puck lights in my bedroom).
I'm slowlly (lamp at a time) going all LED.
