โFeb-16-2021 06:18 PM
โFeb-17-2021 03:30 PM
coolmom42 wrote:time2roll wrote:
3000 watts should run that house fine. Electrician will probably put the critical items on a 120v sub panel in addition to installing a switch and a power inlet to connect power.
My generator is 4000 watts. It would be nice to be able to run the whole house, including TV & internet. Not essential, but nice.
โFeb-17-2021 02:11 PM
โFeb-17-2021 01:47 PM
This is the switch that I had installed in my house for use with my 3K inverter generator. Works great and allows you to watch the wattage being drawn on each leg.
I think the link you provided is for a 240V input, there is also a 6 circuit 120V 30A available from the same mfg. That's what I have.
If all you want to do is power one or two circuits this is another option.
https://ezgeneratorswitch.com/
If you go the transfer switch route make sure it is compatible with your generator. unbonded neutral generators (ground neutral not bonded) transfer switch wiring is different than a bonded neutral generator.
EZgenerator switch can be configured for both, IIRC the other 6 circuit transfer switch is only configured for use with an unbonded neutral generator. Many if not most portable generators are unbonded neutral.
My generator is the 4KW Onan built into a motorhome. How do I determine whether the neutral is bonded or unbonded?
โFeb-17-2021 12:49 PM
coolmom42 wrote:enblethen wrote:
To determine grounded neutral, you need to isolate genset out put, start genset, you should have 120 volt between both neutral and ground. You should have continuity and no voltage between neutral and ground.
I am guessing you have a transfer switch in your rig!
Yes, in that the generator automatically feeds the power panel without plugging the power cord into the generator. (Although the previous owner told me that was necessary, he was wrong.)
I don't think that would have any impact on connecting to the house panel.
โFeb-17-2021 12:37 PM
coolmom42 wrote:time2roll wrote:coolmom42 wrote:Is it hardwired? What are the electrical requirements?
I need to run the furnace blower. No way to plug it into an extension cord.
I have a dozen home furnaces and they all plug into a standard wall outlet up in the attic, garage or heater closet.
My furnace & blower are outside in what is called a "GasPack" unit. It's the only configuration of central heat/ac that will work in my 1960s ranch style house with crawl space and low attic space. They are pretty common around here.
โFeb-17-2021 11:45 AM
coolmom42 wrote:If that is the case you should not have the huge power requirement but may require 208-230v.
It's a gas furnace with electric blower, in a package unit with the AC, which uses the same blower. I am quite familiar with the utilities in my home.
โFeb-17-2021 11:35 AM
โFeb-17-2021 11:31 AM
time2roll wrote:coolmom42 wrote:I think that is a heat pump, not a furnace.
Yes you need to adjust the power requirements accordingly.
โFeb-17-2021 11:28 AM
SAR Tracker wrote:
We usually lose power a couple of times a year (winter, wind, fires, ect.). Our 5500 watt portable provides plenty of power, if used judicially. An extension cord run into the house to a power strip for the TV (on cable, interestingly, cable never goes out when the power does - underground), run the refrigerator about every 4 hours, the chest freezer is good for at least 12, laptops can run with the TV. A wood stove heats at least the living room, and eventually the whole house. HWH and furnace are both 240, neither work on gen power.
โFeb-17-2021 11:26 AM
valhalla360 wrote:Dutch_12078 wrote:
Be aware many RV generators do not provide 240 volts, so you won't be able to run any appliances that call for it, such as most deep well water pumps, etc.
Since the OP specifically covered the water supply as being city water, not an issue.
To the OP: You are golden with what you want to do. Just a question of how much prep work you want to put in from minimal and run extension cords to a built in system with automatic transfer switch feeding a subpanel for the items you want to run off the generator. Since you are asking the question, I'm going to say, get a professional to set it up for you as you likely don't have the knowledge to do it right.
โFeb-17-2021 11:02 AM
Bud
USAF Retired
Pace Arrow
โFeb-17-2021 10:33 AM
โFeb-17-2021 10:29 AM
โFeb-17-2021 10:26 AM
โFeb-17-2021 10:24 AM
