using Solar controller and 24v power supply
MrWizard
Moderator
Moderator
video of install description
24v ebay power supply, morning star mppt controller
for charge control
OEM converter removed
MPPT solar controller with 24v power supply
I can explain it to you.
1997 F53 Bounder 36s
6 REPLIES 6
westend
Interesting alternative to a converter but if he doesn't use the controller for PV power, it could be done cheaper (as we all know).
One thing that always gets me is that he has the layout of everything about 90% there but misses out on a few things--#1. If you're about to locate electronic devices, it may be a good time to move that water pump. #2. Invest in some wire management hardware, there's no need to make loops of wire and tape them in pairs every few inches. The amperage limit is probably determined by what he wanted to pay for a controller. The 15 amps is probably adequate for the type of use he sees, I'm guessing no generator is ever used.
'03 F-250 4x4 CC
time2roll
Kinda backward doing the power supply first and then contemplating actual solar panels.
Bit of a slow charge for running a generator. 30+ amp would have been better.
I don't get the switch. If it is programmed right the switch is redundant(and looks bad).
Almot
Yep. 25-30A is what he needs. I would say Rouge 30 but they don't make it anymore.
MrWizard
Moderator
Moderator
i like the 'rocker switch' voltage selection for battery top off 'absorption'
the thing is he is limiting the charge output
15 amp controller, 14.4 amps xx volts less than 200w from a 360watt power supply
he needs a bigger size controller
pianotuna
Nomad III
Nomad III
He might have been better off with the Tristar 45 amp unit.
Regards, Don
MEXICOWANDERER
Ummmm? Emergency repair?
