โMay-31-2018 10:10 AM
โMay-31-2018 05:49 PM
time2roll wrote:
So just cut a hole near the top and apply a vent grill.
My front compartment is so unsealed I skipped the whole vent tube thing 12 years ago.
โMay-31-2018 05:24 PM
SoundGuy wrote:
This would be an ideal application for AGM batteries.
tim1970 wrote:
I am seriously considering this to avoid all of the headaches about proper venting. I should be perfectly fine doing this. Which AGM battery do you recommend? Also, how much more cost am I looking at? 2X, 3X, or even more?
โMay-31-2018 04:41 PM
SoundGuy wrote:
This would be an ideal application for AGM batteries. For sure more costly but they do eliminate the venting issue and need no servicing at all, other than proper recharging of course. Exactly why when I replaced my aging tongue mounted flooded battery I instead mounted an AGM in the trailer's front pass through cargo compartment where I could connect to the inverter with short, heavy gauge 18" cables for minimal voltage drop, even under heavy load. :B
โMay-31-2018 04:36 PM
โMay-31-2018 02:51 PM
โMay-31-2018 02:18 PM
โMay-31-2018 01:16 PM
โMay-31-2018 01:09 PM
โMay-31-2018 12:38 PM
CA Traveler wrote:
Inadequate ventilation as you describe. Since you already have a vented battery box use the same ventilation for a new battery box for the new batteries.
โMay-31-2018 12:34 PM
โMay-31-2018 12:23 PM
โMay-31-2018 10:27 AM
tim1970 wrote:
I am about to replace my 12volt with 4 6volt batteries.
