โJul-29-2018 07:17 PM
โJul-30-2018 06:49 PM
2oldman wrote:dieseltruckdriver wrote:But there's a dongle ( I think it's called) that has a display you had to use to set this up. That reads nothing?
I didn't get the model with Bluetooth, I don't see a need for it for us, so no I can't.
I'm sure you've gone through the troubleshooting in the manual.
โJul-30-2018 06:48 PM
Donnoh wrote:
I just bought one of these but haven't installed it yet. If I were you I would be suspect of the cable between the shunt and the display. Have you tried another cable yet? The voltage displayed may be taken from the display supply and the current and battery temp function come from the shunt.
Did you purchase a battery temp monitor? If you did do you get a temp reading?
As a former PLC and automation controller programmer I feel your pain.
โJul-30-2018 12:00 PM
โJul-30-2018 11:53 AM
โJul-30-2018 11:31 AM
2oldman wrote:
You don't get readings from either the bluetooth transmitter, or the phone app?
โJul-30-2018 10:43 AM
โJul-30-2018 10:37 AM
โJul-30-2018 09:58 AM
shastagary wrote:
are you sure it is set up correctly in the settings is it set to the default shunt setting of 500amp and 50mv in the settings it is adjustable to be able to use different shunts. manual
โJul-30-2018 09:46 AM
โJul-30-2018 09:34 AM
โJul-30-2018 08:57 AM
โJul-30-2018 08:56 AM
โJul-30-2018 08:51 AM
โJul-30-2018 08:29 AM
2oldman wrote:
Is the little red power wire to the shunt hooked to + ?
โJul-30-2018 08:27 AM
