Apr-06-2021 11:03 AM
Apr-07-2021 03:06 AM
StirCrazy wrote:
what charger are you using?
Steve
Apr-06-2021 08:07 PM
Apr-06-2021 07:25 PM
Apr-06-2021 07:15 PM
Apr-06-2021 06:49 PM
Apr-06-2021 06:36 PM
Apr-06-2021 05:58 PM
jaycocreek wrote:2oldman wrote:
I see nothing wrong with those numbers, but I am kinda surprised to see a 'resting' 12v battery above 13v. Is it still being charged?
24 hours to fully charge? Must be a small charger. Very small.
Sorry,I should have added Lifepo4 as being the battery..The charger is a Noco Genius 10 amp smart charger with a lithium setting..I have a Lifepo4 charger on the way that charges to 14.4 volts instead of 14.6..
With the Noco Genius 10 and the LFP battery at 13.1 volts,it took about two hours to charge to 14.4 volts,at the start,it was taking the whole 10 amps then down and down to under an amp before it finished and turned off..I sat and watched it the whole time thinking maybe the charger is messing up after the weird bluetooth numbers from the battery bluetooth.
Apr-06-2021 05:42 PM
Apr-06-2021 05:41 PM
Apr-06-2021 05:40 PM
Apr-06-2021 05:23 PM
Apr-06-2021 11:51 AM
Apr-06-2021 11:49 AM
Apr-06-2021 11:23 AM
