โJun-04-2013 11:17 AM
โJun-05-2013 09:37 AM
bigcitypopo wrote:
let me know what ya think. pretty straight forward, no?
โJun-05-2013 09:12 AM
Salvo wrote:
If you abuse any meter it will burn out. Your scare tactics are not valid. This is a 500A shunt! You need in excess of 500A for a fairly long time to burn this shunt.
In general, if a shunt does blow, it's the the fault of the shunt but the person who installed it. Shunts must be derated by 50%. If maximum current in a shunt application is limited to 50A, then use a 100A shunt. In the OP's case the shunt is rated 500A. It's overkill, but it will never blow. The battery in-line fuse will blow first.
As far as using shunts vs. hall effect, I believe shunts have more accuracy and can measure small currents.
BTW, that looks like an excellent meter. Go for it!
Salpianotuna wrote:
I don't like the shunt because it IS possible for it to burn out.
โJun-05-2013 09:03 AM
โJun-05-2013 08:48 AM
โJun-05-2013 08:15 AM
โJun-05-2013 08:08 AM
โJun-05-2013 07:21 AM
โJun-05-2013 07:06 AM
โJun-05-2013 06:46 AM
โJun-04-2013 09:13 PM
OnaQuest wrote:pianotuna wrote:
Hi,
I prefer hall effect ammeters myself, as no shunt is required.
hall effect
That's your preference, but all you have is an amp meter, for about the same price, where the other meter has the logic behind it to display AH used, Amps flowing, directional amp flow and voltage. Hardly the same function. I prefer shunt based operation.
โJun-04-2013 08:34 PM
โJun-04-2013 08:11 PM
pianotuna wrote:
Hi,
hall effect
โJun-04-2013 05:52 PM
โJun-04-2013 05:49 PM
tenbear wrote:
Looks good but the price will probably go up. Still 5 days more to go.
Not clear to me how it switches between the various functions.
โJun-04-2013 05:09 PM
