โJun-04-2018 10:53 AM
โJun-05-2018 03:06 PM
โJun-05-2018 02:14 PM
โJun-05-2018 01:39 PM
โJun-04-2018 05:24 PM
โJun-04-2018 05:23 PM
โJun-04-2018 04:39 PM
MEXICOWANDERER wrote:
- Outlet in your garage has 20-amp service. Looks like 15-amp but has a cross-cut in the neutral slot
- Use a 12 gauge extension cord
- Flip breakers inside rig to turn off everything but the A/C
- The A/C should start and run. As long an nothing else is connected the 20 amp breaker will carry the load.
โJun-04-2018 04:25 PM
Boomerweps wrote:MEXICOWANDERER wrote:
I have connected several brands of 15K roof airs to a 20 amp receptacle.
Not only do they start fine, they RE-start fine against high head pressure. This is for testing not a permanent installation.
THIMK!
30 amp to 20 amp
Rigs connect to 30 amp service AND operate their hot water heater, refrigerator, and converter AND the 15K roof air...
What he said.
I picked up a Kill-A-Watt plug in meter at Harbor Freight on sale a while back. I took the time and plugged it in to my TT AC line using a 30 to 15 amp adapter. The house circuit it plugs into is 20 amp (former submariner, I have all my house circuit breakers and what they supply mapped out ;). My AC is a 13,500 BTU and measured a constant 12 amps on high. Actually 1446 watts.
โJun-04-2018 03:06 PM
โJun-04-2018 02:40 PM
THIMK!
30 amp to 20 amp
โJun-04-2018 01:24 PM
โJun-04-2018 01:04 PM
Mickeyfan0805 wrote:
We are headed to TN and then on to FL in July. This will be our first trip of the year and, given the temps we will be facing, I'd like to test the AC before we leave - just to make sure it is in working order. We have no 30a plug at home. Other than pulling into a campground somewhere, is there any option anyone can suggest to do a quick test on the unit?
โJun-04-2018 12:50 PM
โJun-04-2018 12:14 PM
โJun-04-2018 11:55 AM
