Water heater leaking. Now what? (Atwood gc6aa-10e)
campingwiththor
My water heater is leaking at the cold water inlet connector point. It's a pretty constant drip drip... Currently dripping into a bowl...
I would like to know if there is a fix wherein I could place some putty type material around the connector? Or do I need to unscrew the connector and reseal? If I need to unscrew it... What do I use to reseal? i.e. Standard plumbers tape?
Thank you for you help.
Cwt
2002 Ford F350 Diesel Dually,
2003 Bigfoot 2500
"Office Maxx" passed away in January 2007.
Youtube Tribute Video: The desert to Alaska with my dog
http://youtube.com/watch?v=3JBnGGn0GOA
7 REPLIES 7
wrgrs50s
It might be a plastic checkvalve that is screwed into the cold water inlet, they are bad about cracking and leaking. It's recommended to replace with a brass checkvalve.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
Bobbo
gbopp wrote:
Do it once and do it right.
Take the time to disassemble it and make the necessary repairs.
You'll thank yourself for doing it the right way. ๐Ÿ™‚
YOU STOLE MY LINE! Only, I reverse it. I say "Do it right, do it once."
Bobbo and Lin
mgirardo
We've had the plastic fitting on the cold water inlet back off several times while traveling. The last time it happened, I removed the fitting, cleaned the fitting and pipe threads. Then put some pipe tape on it and cranked it down tightly. Hasn't been a problem since.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Gjac
Over the years both hot and cold water junctions in back of the WH leaked. Both times it was while camping in extremely cold weather in the teens overnight. I re tightened by hand and all was well again. Have you tried to re tighten the fitting?
midnightsadie
no patch job, just when you want everything going good, the patch will let go, called carma,you should do it right the first time.
gbopp
RJsfishin
Use sealer or tape on tapered pipe threads only.
Any other fitting does not use a sealer.
It may be a rubber seal that has deteriated.
Take it apart to see what you are up against, but do it when you have access to a hardware store,
In the meantime shut off the water to the heater, or turn off the pump.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
