โSep-25-2013 08:02 AM
โDec-01-2015 06:14 PM
โOct-09-2013 07:34 PM
โSep-27-2013 11:07 PM
So wrote:PaulJ2 wrote:
I still think you will find that the ICM ignition module is the problem. Diagram shows that there are two ways to kill the spark--by the ignition key switch grounding the spark, or the yellow wire from the low oil device grounding the spark. Both cause the coil black wire to go to O ohms stopping the engine.
The diagram also shows that if you disconnect the ignition coil's primary side black wire (at the coil), it will completely isolate the ignition coil from the rest of the circuit... including the ICM.
If the ignition coil is fully functioning, properly installed and the spark plug is equally functional, HV spark will be produced whenever the ignition coil's black wire is disconnected... and the flywheel is spun fast enough.
This does NOT imply that the engine will run, it does however, validate the functionality of the ignition system.
โSep-27-2013 04:02 PM
โSep-27-2013 03:49 PM
โSep-27-2013 02:53 PM
โSep-27-2013 11:54 AM
โSep-27-2013 09:18 AM
โSep-27-2013 08:23 AM
โSep-27-2013 08:07 AM
โSep-27-2013 07:30 AM
Thach2264 wrote:
p.s I have some setting that I didnt know, prevent me from viewing the attached service Robert insert.
โSep-27-2013 07:26 AM
โSep-27-2013 07:06 AM
โSep-27-2013 06:59 AM
