Howard
You my friend might have hit the nail on the head! I was thinking it was kind of acting like the motor was not getting enough "juice" and today the passenger side was to the sun here in Quartzsite ah about 1/2 way up she stopped, had to wait about 5 minutes and she groaned and finally made it in. I also was having almost the same issues with the awning over the door.
This connection, was it feeding 12 volts to the controller or was it the connection between the controller and the awning motor?
I'll start traacing the wires to the controller to determine where they go. I do know internally they run just above the upper cabinets on the passenger side. Just need to trace where they go down. Could be around the fridge.
Thanks ever so much for the info. I'll sniff it out. Nice that Fleetwood labels the 12vdc wires.
Will update any findings here. Oh, will also retract in the early AM when its cool here in the desert to see if reacts differently.
Thanks again.
Jerry
Thanks for the info about the spring. I do all my own work and I am in RV tech biz as well. Those springs are scarey! I think Howard may have come up with the answer. Thanks for your suggestion!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
