Oven Thermostat (oven control) with the 3 lines should also have a wire coming from it
One line is gas to oven burner
One line is for the thermocouple located above pilot assembly
One line is gas to pilot assembly (copper line and should NOT be crimped)
Wire goes to oven thermostat bulb located on back wall of oven
Turning oven knob to 'pilot' position/pushing it in holds magnet in allowing gas flow to pilot assembly. With pilot flame lit the flame should heat up thermocouple within 5-10 seconds and send a millivolt current back to oven control holding magnet in so gas flow will continue when knob is released.
Turn knob to desired temp......thermostat bulb allows gas flow thru oven control to main burner which is ignited by pilot flame.
You stated you LP at the inlet to control but nothing from any of the lines when holding knob in........two different control valves????
Both can't be faulty so are you SURE that oven knob is in 'pilot' position and is going in COMPLETELY???
Turn knob to pilot position........remove knob and then push/hold shaft in fully while someone lights pilot flame.
HERE IS SERVICE MANUAL
