โJun-17-2013 09:23 AM
โJun-24-2013 01:59 PM
peirek wrote:~DJ~ wrote:peirek wrote:~DJ~ wrote:peirek wrote:~DJ~ wrote:
Went down to Idaho Marine today and got a 12 volt receptacle rated up to 20 amps. 8 gauge wire and connectors. Installed it all and my Engel runs great!!!
The automotive 12v went in the junk drawer!!!
Thanks everyone!!!
DJ
You do have a fuse in line correct. Your statement earlier (wired direct to the battery) suggests maybe not.
Ummm....no. The cooler has a fuse. Should I add an inline?
Yes. You are installing an unfused socket tied directly to the battery. Bad things can happen.
20 amp inline fuse installed. Thank you!!
Very good. Makes me sleep better....:)
Last question (hopefully not to late) wire gauge is 12AWG or larger?
โJun-22-2013 11:20 AM
Thanks everyone!!!
DJ
โJun-22-2013 07:39 AM
Thanks everyone!!!
DJ
โJun-22-2013 01:10 AM
mkirsch wrote:
"Won't run" how? What happens when you plug it in and turn it on? Does it pop fuses, or stand up and sing the Star Spangled Banner, or what?
โJun-21-2013 04:24 PM
Thanks everyone!!!
DJ
โJun-20-2013 07:38 AM
โJun-20-2013 07:14 AM
jhilley wrote:
I am also wondering what an Engel is. It may be that the socket is just slightly different and the center positive connector on the plug doesn't reach the contact in the socket.
โJun-20-2013 07:06 AM
Thanks everyone!!!
DJ
โJun-19-2013 04:45 PM
โJun-19-2013 03:26 PM
MEXICOWANDERER wrote:
I am going to take a wild burro stab here and offer a suggestion that the "new" socket is not allowing some accessories full electrical contact between socket and plug. I went mad-dog with this problem several years ago and then did a Jack Nicholson with a pair of diagonal cutting pliers.
Now, everything is MARINCO marine grade, and no more poltergeist grade problems.
โJun-19-2013 03:11 PM
Thanks everyone!!!
DJ
โJun-19-2013 11:49 AM
โJun-18-2013 10:00 AM
โJun-18-2013 09:46 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
