โMar-25-2016 05:08 PM
โApr-11-2016 06:06 PM
โApr-11-2016 04:13 PM
โApr-11-2016 12:55 PM
John&Joey wrote:Yep, Salt will do that because it doesn't burn. Its already had a blowout when the burner was out. My primary concern once I can keep the thing lit is the occasional backfireing I see
Might just as well add my 2c's. Go up on the roof of the rig with a leaf blower. Take both covers off and then shoot some air down the shaft. Make sure no one is standing near the bottom panel when all the **** comes flying out.
You're near salt water, the flue has metal in it, and a nice blue flame with an OEM burner has tips of yellow here and there. Thinking you got some very fine stuff falling into that flame when you're sending a stream of hot air up the flue.
For the shutting off, I would always do what Chris says first.
โApr-11-2016 12:53 PM
Chris Bryant wrote:its loose in its insulator I can move it anywhere I want with very slight pressure. Waiting for Package Man... Stby
I'll say again, electrode adjustment. That can cause all of the problems you are seeing.
โApr-11-2016 07:37 AM
โApr-11-2016 02:25 AM
โApr-10-2016 09:50 PM
โApr-07-2016 06:15 PM
โApr-07-2016 01:06 AM
โApr-06-2016 10:59 AM
SCVJeff wrote:So this is a brand new burner tube, that was my question, if that is the case the slots in the tube regulate the propane flow. Is the tube the same as your old one? When I was trying to find a replacement for mine I noticed some tubes had an extra slot. If your tube is an exact replacement I would look more at the propane delivery system, (gas valve, orifice).
This is a brand new burner assy. I've cleaned the old one but waiting for my meter to show up to make sure the regulator is behaving before calling the vendor back again. Hopefully by the end of the week
โApr-06-2016 01:46 AM
โApr-05-2016 10:43 PM
โApr-05-2016 09:01 PM
SCVJeff wrote:
Gjac: it's so random it's hard to know what really fixes it. I can but my finger over the home and adjust the flame but obviously not for long. I'll look at the pressure this weekend hopefully and see where it sits.
Randy: the burner chamber is press-fitted into the jet so I can't get anything in there. About all you can do with these is turn them upside down and blow them out. One thing I haven't done is pay attention to when it happens: right at power on when everything is cold, or after it warms up ?
โApr-05-2016 10:01 AM
