โJan-10-2018 08:15 AM
โJan-23-2018 07:09 AM
pennyrobbins wrote:
We have a really small camper van and are simply looking for something to use when we're not near civilization. How big are the cassette toilets really? Would something like the ***Link Removed*** be worth getting or is it just junk? We're honestly more concerned about space than comfort at this point.
โJan-23-2018 07:08 AM
โJan-11-2018 04:37 AM
โJan-10-2018 11:39 AM
โJan-10-2018 09:25 AM
rr2254545 wrote:
I got the Dometic 310 for the motor home and love it - save $50 and get this one
โJan-10-2018 09:23 AM
Old-Biscuit wrote:
Dometic 320
*Right side foot pedal (easy snap in/out water valve)
*1 pint water usage per flush.....rim flush
*toilet bowl seal....easy R/R
*Bowl/base factory sealed
Less parts/easy seal & water valve replacement
But if bowl/base factory seal leaks.....replace complete toilet
Slightly Larger Toilet
22" Depth
19 3/4" Height
14 3/4" Width
Dometic (Sealand) 510
*Left side foot pedal (remove side cover to access water valve--then remove screws to pull water valve)
*<1 pint water usage per flush....standard flush from rear of bowl
*toilet bowl seal.....separate bowl/base to access seal. Adjustment band used to hold the two parts together
More parts/must disassemble to R/R parts
But parts can be replaced vs tossing whole toilet
Slightly smaller...still a full side toiet
20 1/2" Depth
18 3/4" Height
15 1/4" Width
โJan-10-2018 09:16 AM
โJan-10-2018 09:08 AM
