Winnebago Inverter NLA
mmccray100
I need to replace the inverter in my 99 Winnebago Chieftain. Winn says it and the part that replaced it are NLA. The Winn part # is 099048-03-000
The original was made by Dimensions. I have a 30 amp system.
Has anybody found a suitable replacement?
Thanks,
Mike
7 REPLIES 7
1995brave
Since you are right outside Houston, TX, drive over to PPL Motorhomes and tell them what you need.
Checked the Winnebago website and you are looking for a 130 watt inverter, probably for the TV. They can be picked up at almost any department store or auto parts store. You may not find a 130watt, but you will probably be able to find a 200 watt for around $40.
Iโ€™m in Virginia
You know the OP was a June 2018 post. It may be resolved by now.
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800 Reverse Trike
Itโ€™s tough travels on this forum these daysโ€ฆ.
so true.
USN EN2
2015 Voltage 3200
Whatโ€™s the closest to the orginal
MrWizard
Moderator
Moderator
See the responses, in your thread in class A
I can explain it to you.
1997 F53 Bounder 36s
