A few ?? on winter storage.
Do you leave your batteries in the RV (SE Massachusetts. A week or two at really cold temps, otherwise usually around freezing)
Do you run the converter all winter or do you use an auxiliary battery maintainer/charger?
While I'm at it......I used air to blow out the lines and ran antifreeze through the pump with the Camco kit. Put AF into all the drains. Do you leave the faucets open? Leave the low water drains open? Leave the grey/black waste gates opened or closed?
Thanks
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
