Your mistake was in assuming that there is an actual STANDARD.. now on the 120 volt side of life TRADITIONALLY green is ground. White is neutral and Black or Red hot or hot switched (Red is often used for that) But it is not, as far as I know a STANDARD so much as a tradition.
On the 12 volt side of life about the only Tradition is Black is negative and Red positive. all other colors are whatever the builder want them to be and even that is not followed in RV's where WHITE is often the negativw and Black is Positive.
So.. ALWAYS meter the wire ALWAYS only way to be sure.
Back in the 50's The dash on your car was Steel and grounded so the SHELL of a cigg-ligher (not called 12 volt accessory) socket was negative on 12 volt cars made in the USA (positive on an English Ford)
Then they started making dashes out of plastic and the worker whould hook up the wires to the lighter/accesory socket without paying attention.> Thus the Shell on many was Positive and the "tip" (Center contact" Negative.. I have (Somewher) a lighter plug with a LED light in it.
Green = Normal
Red = Reverse
Yellow = AC not DC
