โMay-26-2018 03:40 PM
โJun-05-2018 09:56 AM
โJun-05-2018 09:20 AM
โJun-05-2018 05:59 AM
โJun-04-2018 09:59 PM
BFL13 wrote:
Good news. What was the positive amps from solar before you turned on the MW? (then add that to the 119) Or--what would the actual draw be with no solar? Also to clarify, what is the MW's 120v input watts required according to its label? If can't get at that, then what is the rated cooking power of that MW? (can estimate input based on other known MW numbers)
โJun-04-2018 07:55 PM
โJun-04-2018 06:58 PM
MEXICOWANDERER wrote:Very true about most off-shore electronics, built to sell with the cheapest componetry available. A casual observer doen't understand why a $.30 capacitor can't be used instead of the $.25 one but Asian bean counters add it all up and choose the cheapest, everytime. There are also other issues but too boring for this thread.
Maybe it's just me but I have had horrible luck with cut-rate inverters. Anything from a sleaze-bag cigarette lighter model to a 2000 watt two hundred dollar model as bizarre looking as a Dyson vacuum cleaner had failed within months. The 2000 was for Jesus and the big chest freezer at the restaurant.
Made a decision -- no freakin' more chew and spit waste of money inverters. My Trace 4024 is near immortal and the Samlex PSW 300-watt has rendered six years of flawless service. As far as failure cause the cheapos died from component failure within the control primary and not within the power (FET) finals.
Cheap At Any Price means cheap quality. The Chinese spit them out without ever starting them up to check. A way around this is to find a miracle cheapo with 500 5-star reviews. Good luck.
โJun-04-2018 06:12 PM
โJun-04-2018 05:25 PM
โJun-04-2018 09:29 AM
pianotuna wrote:
So glad this worked out well! Do you mind sharing the cost of the inverter?
โJun-04-2018 08:20 AM
โJun-04-2018 07:54 AM
โJun-04-2018 07:43 AM
โMay-31-2018 08:35 AM
โMay-31-2018 07:59 AM
