โJun-01-2018 09:49 PM
โJun-05-2018 08:30 AM
BFL13 wrote:
Using the converter to support the battery bank while it is being pulled down by the inverter is a good technique. Another way is to use alternator charging to support the battery bank.
โJun-05-2018 08:05 AM
โJun-05-2018 08:03 AM
time2roll wrote:
I have read a 40 amp IOTA will overload a Honda 1000. This is why I don't recommend 40 amp charging even if some chargers will work. I believe PD voltage or amps sag a bit near full output. Very few list PF correction so it is a bit of a gamble at about 40+ amps.
Xantrex Power Factor White Paper
โJun-05-2018 07:37 AM
NRALIFR wrote:
I have a Yamaha EF1000iS that I carry with me all the time. My TC has a PD4645 converter-charger, and the Yamaha is capable of running the charger even in boost mode with wattage to spare. I use the Yamaha about 95% of the time vs. the built-in Generac LP generator. It will run everything except the AC. I can even use my microwave while running the Yamaha by plugging it into a 1500 watt psw inverter. Iโve run the microwave that way for nearly an hour before the battery got down to about 50%. When weโre dry camping, the Yamaha gets used a lot.
โJun-05-2018 07:28 AM
โJun-05-2018 07:15 AM
โJun-05-2018 06:48 AM
BFL13 wrote:I don't know what the VA is for my Stanley charger, but my usage is "continuous" while doing a 40 amp charge.Tom_M wrote:
I have no problem with my Yamaha 1000 watt powering my Stanley 40 amp charger.
It all turns on the meaning of "continuous" and the margin for going over the specs. My 40amp VEC1093DBD on a Honda with a Kill-A-Watt:
125.4v, 8.4a, 688w, 1063VA, PF 0.64 (output 40.4 amps, battery 12.8 and rising.)
My 35amp Vector 1092A was:
125.9v, 6.89a, 568w, 868VA, PF 0.65 (output 33.2a)
โJun-04-2018 11:48 AM
โJun-04-2018 05:50 AM
โJun-04-2018 04:37 AM
โJun-03-2018 04:19 PM
โJun-03-2018 03:39 PM
bikendan wrote:
For the little amount of money more a 2000w costs, to me it's a no brainer.
โJun-03-2018 03:32 PM
โJun-03-2018 09:40 AM
wa8yxm wrote:
He needs to limit his charging current to around 30 anps.
Or he can upgrade the generator (What I'd do).
โJun-03-2018 07:43 AM
