โNov-10-2017 10:08 AM
โNov-12-2017 09:54 PM
โNov-11-2017 07:06 AM
2oldman wrote:
..not that anyone needs fused panels.
โNov-11-2017 06:31 AM
โNov-10-2017 02:15 PM
โNov-10-2017 01:39 PM
red31 wrote:
Yes, if the adventurer came with remote sensors, use both.
450 watts exceeds the 400 watt spec on the back of the controller.
how does this controller handle over power input?
โNov-10-2017 12:26 PM
MEXICOWANDERER wrote:Also, unless the panels are aimed perfectly, you won't get the rated watts.
You'll only test the controller's wattage limit if you solely rely on the panels to recharge depleted batteries. This is certainly not a recommendation to do so merely an explanation as to why it has not been an issue up to now.
โNov-10-2017 12:21 PM
โNov-10-2017 12:07 PM
โNov-10-2017 11:22 AM
โNov-10-2017 11:19 AM
โNov-10-2017 10:53 AM
โNov-10-2017 10:51 AM
