โNov-11-2021 05:19 AM
โJan-23-2022 08:29 AM
โJan-22-2022 09:13 AM
โJan-22-2022 08:57 AM
โJan-21-2022 10:52 AM
rjstractor wrote:
Those older trucks are definitely light compared to today. I used to have a '72 F100 2WD with a GVWR of just 5000 lbs, not much more than an empty, stripped down F150 today. Empty and from the factory it had to weigh under 4000.
โJan-21-2022 10:49 AM
โJan-21-2022 09:24 AM
โJan-21-2022 08:18 AM
โJan-21-2022 08:06 AM
specta wrote:
I just took it across the scales this afternoon.
Myself, a full tank of gas and two spare tires in the bed weigh roughly 400 pounds making the truck about 5000 lbs dry.
The truck also has an aftermarket auxiliary gas tank but it is empty so it might not even weigh 5000 lbs from the factory.
So with a 7700 lb GVW rating it is capable of carrying around 2300 lbs.
Its kind of a light weight for a 3/4 ton truck. ๐
โJan-20-2022 04:47 PM
โJan-20-2022 04:46 PM
cummins2014 wrote:
It will definitely raise your heart rate , especially when you are on the brakes , and you start sliding sideways , so you let off , and then repeat , I came off a couple a bit faster then wanted . Or climbing and spin out , I got to when Iโd lose momentum Iโd let off throw it in reverse, and pop the clutch to catch me going backwards , that also raised the heart rate . Or spin out kill the engine , both feet on the brake , and sliding backwards, that was exciting .:)
โJan-20-2022 02:46 PM
specta wrote:cummins2014 wrote:
I had a 64 Dodge Power Wagon that would do that , I'd be coming off a steep road in granny, and the transfer case would jump out of low range . It would be pretty exciting keeping it slowed down . ๐
This is a first for me and I don't need that kind of excitement. LOL
I've still got lots to do before tackling the t-case.
โJan-20-2022 11:17 AM
โJan-20-2022 06:14 AM
specta wrote:
Bought some oil while I was in Salt Lake yesterday.
I was hoping to find some blended oil with zinc but no luck this time.
New shocks, front brake pads and new u-joints for the two front drive axles arrived yesterday.
I took it out and was pushing it pretty hard in 3rd gear low range and it kept popping out of low range.
It looks like the transfer case is due for an OH.
All I need now is some time to work on it.
โJan-19-2022 07:58 PM
โJan-15-2022 09:03 AM
