03 F350 DRW GVWR vs 06 F350 DRW GVWR
rowekmr
I see that some of the 03 F350 DRW I have seen have a GVWR of 11,500 but the newer 06 F350 DRW have a GVWR of 13,000. Is the difference in the springs or is it a gain just on paper? I know they switch spring design (leaf vs coil) but did they increase the capacity or the axles or hardware? Thanks
10 Lincoln MKS Ecoboost
07 Lincoln Navigator
00 Newmar Dutch Star 3851
4 REPLIES 4
ScottG
If the truth could be known Ford probably made changes to everything during that time from the stuff behind the grill to the bracket that holds the rear bumper.
It's not just going to be a bigger spring pack.
mdamerell
Starting with the "tow wars" in 2005 Ford upgraded the suspension, and brakes. My 2004 dually is 11,500# a 2015 equivalent is 14,000# GVWR.
Ford Tow Guides 20002 - 2015
My truck weighs about 8,000# so that's an increase from 3,500# to 6,000# of cargo capacity. GCWR went from 20,000# to around 32,000# which is huge!
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
FishOnOne
Ford increased the spring size (width) and increased the frame thickness in 05.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
JIMNLIN
https://www.fleet.ford.com/truckbbas/topics/techspec.html
use this handy spec sheets on the different year models you need for the mechanical specs on the components you mention.
