It is probably under the stove or the fridge.
What is in the black panel under the oven...
There appears to be something under the fridge shown here as well. Look behind that panel..
The CONVERTER/CHARGER is usually part of the Power Distribution Panle and may be mounted in the bottom compartment.
If you found the DC Distribution Panel where all of the 12VDC fuses are located give us the model number of that. Maybe we can pull that up on the internet and identify what converter goes with that.
Did you find two fuses off to themself on the 12VDC Power Distribution Panel that maybe was labeled REV POLARITY or something to that effect. They will be maybe two 30AMP fuses - off to them selves.
You mentioned an inline fuse did you find one of those next to the battery terminals - was it a good fuse?
Do you have a DC MULTIMETER to test DC voltages... These are very inexpensive. WALMART-LOWES-any number of automotive parts places with a price range of $7-$20...
This is what a multimeter looks like
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
