Mar-06-2018 06:56 PM
Mar-07-2018 07:26 AM
desertroad wrote:scout4trout wrote:
The 2016 Ford camper package on the F250 includes rear auxiliary springs as well as a sway bar, so you could probably have Ford install those. But I'd opt for the Big Wig sway bar. Another member on this forum had a 2016 F250 with camper package that didn't feel he had sufficient capacity for his new Northern Lite (about 2,750 dry weight) so he upgraded to an F350. I don't know what model Big Foot you have, but the 2500 series are hefty for the F250. We're maxed on our F250. Probably should have listened to those on here that said we should go with the F350 when we were ordering.
Thanks for the info...Yes, we have a 2500 series Bigfoot, about 2700 Lb wet. My 85 diesel is hauling it fine without any noticable sagging. And I figure if I got a gas instead of diesel F250, it should lighten the truck to make up for the extended cab. You don't really know for sure until it's on the scales. I'm willing to take out the back seats of the extended cab and drive with less in the tanks to shave some more off to get closer to the 2500 Lb limit. Getting an F350 in California may be a lot more pricey with regards to DMV registration fees if I read it correctly.
Mar-07-2018 07:18 AM
Mar-07-2018 07:16 AM
Mar-07-2018 07:10 AM
Kayteg1 wrote:
I was considering adding such plug on my new truck, but from what I check factory puts them in rear corner of the bed.
That require to use cord extension anyway and with tall bed sides on newer trucks, you don't have access to the plug with camper on.
So what's the point?
I plug the extension into bumper plug, drive under the camper and plug camper cord into extension, securing the cables hanging on camper side.
Than lower the camper and I am done.
For years I've been crawling under the camper to pull bumper plug and in dry weather it is not a big deal, but thinking about my knees getting stiffer and stiffer with age and potential for camping in the rain, , the side cable connection is way better.
Mar-07-2018 07:07 AM
Mar-07-2018 07:05 AM
skipro3 wrote:
If you buy your camper from a dealer, they should wire your truck for you. My Lance dealer did anyways. If you are buying a used camper from a private party, then get the camper first as the pin out between brands can be different. Last thing I would do is let a dealer anywhere near my truck other than warranty work.
Mar-07-2018 07:02 AM
Mar-07-2018 06:50 AM
Mar-07-2018 06:14 AM
Mar-07-2018 06:09 AM
Mar-07-2018 05:28 AM
Mar-06-2018 09:47 PM
Mar-06-2018 07:35 PM
Mar-06-2018 07:24 PM
