Mar-03-2017 11:09 AM
Mar-05-2017 04:50 AM
Mar-04-2017 09:00 PM
goducks10 wrote:tinner12002 wrote:
Mine rarely downshifts from 6th unless I'm pulling a pretty steep incline with the cruise engaged. It may drop a couple MPH on a hill but cruise and 6th stay engaged. Only pulling about 12K 5th wheel toy hauler @65mph so its not working hard at all.
Big difference between 4.10s and 3.42's.
Mar-04-2017 04:55 PM
Mar-04-2017 11:23 AM
Mar-04-2017 09:02 AM
Mar-04-2017 08:10 AM
Mar-04-2017 05:51 AM
Mar-04-2017 04:38 AM
Mar-04-2017 02:00 AM
Mar-03-2017 09:30 PM
blofgren wrote:
As others have said it sounds like you need to lock out 6th to keep your RPM's somewhere around 1900-2100. That is the sweet spot for the Cummins and it will pull like a train.
My combo is great in that I sit right in that range in 6th gear right around 65 mph so I can actually pull my 16k fiver up some pretty good grades without downshifting and it will actually accelerate up the hill if I give it some more throttle. Trust me, your new truck has MUCH more pulling power than your old 7.3L, it will just take getting to know it better to get it out of it.
Please let us know how you make out!
Mar-03-2017 07:34 PM
Mar-03-2017 07:12 PM
Searching_Ut wrote:.
I always lock out 6th gear on my Ram while towing. The Asin transmission tends to hunt bad, especially between 5th and 6th. I've also found cruise control costs me almost 2 miles to the gallon while towing so I turn it off often and it allows a fair bit of speed variation in rolling hills. The gear ratio in the SRW's is fairly high, which in my opinion works fairly good as a compromise for when you're running empty at 80ish MPH on the freeway unload in 6th, but still have 5 useable gears for towing. I'm not sure where the claims of seven up steep hills comes from. Mine drops down into 3rd pulling hard fairly often, as did my 2011 2500 with regular output engine towing a trailer that was only 8k. Most freeway pulls you can keep freeway speeds as they only get up around 6 or 7 percent grade most of the time. Mountain highways often get much steeper.
Mar-03-2017 05:44 PM
Mar-03-2017 05:23 PM
