2 inch lift kit??
97psdhost
Is anyone using a rear block lift kit on a ford f350 dually?
I have upper and lower stable loads and still have a little sag. I was thinking I could put a block lift kit on the rear axel and get the ride height back to level. I realize when unloaded it won't be level again, but it is worth it when loaded.
21 REPLIES 21
97psdhost
9920 lbs. on rear axel
Yes I am getting an occasional headlight flash from traffic.
Camper is a 2013 Chalet TS116
bighatnohorse
Do you ever drive the rig after dark?
Is the oncoming traffic flashing their lights at you?
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
Bedlam
Moderator
Moderator
You need more spring pack. How much weight is on your rear axle?
97psdhost
I'll work on posting pics.
Here is the link to the system installation
http://www.realtruck.com/shared/pdf/manufacturers/185/66-2024-66-2025-installation-instructions.pdf
Grit_dog
Navigator
Navigator
So it would only be for appearance sake? Don't do it. As said above, lift blocks are not your friend.
Jaxom
Show us a side-view picture. If it's only "a little sag", perhaps your best bet is just to get used to it.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
AH64ID
Blocks and torque aren't friends.
I'd do airbags.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
