Jul-14-2018 08:57 PM
Jul-19-2018 11:12 AM
Jul-19-2018 10:30 AM
Jul-17-2018 02:35 PM
Grit dog wrote:
Rear axle is good for 10klbs, not 6klbs despite what dodge says. Of course springs, tires and wheels aren't, but....
With 3195 lbs being the best you can do for a 17" tire, I'd say they leave a lot on the table compared to 18s or 20s. And with a 2wd, if bed height is an issue, the 5ver may have flat tires!
Jul-15-2018 09:54 PM
Jul-15-2018 07:09 PM
Grit dog wrote:
Can't help with what sort of 5ver. Anything under 12-14000lbs is a good match though in general.
Couple things about the truck, if it's in good shape and you're planning on keeping it for a long time.
1. Ditch the OE 17" wheels. You can find OE 18" or 20" takeoff wheels and tires cheap and they will have more available tore capacity and choices.
2. Stock 3rd gems leave a little to be desired in the power department when towing gets heavy. With a stock trans you can do a mild tow tune that won't destroy the trans. 30-40hp and 60-80 ft lbs bump in power. If you are serious about making th ole 05 a real towing beast then a built trans is in order and you can bump up 100hp or more easily.
3. Exhaust brakes are worth the $ IMO. I'd doo this first before any other mods.
4. The above 3 mods are the only things you would need to do to make that truck hang with a brnad new one up and down the Mountain. But you're looking at about $7k min to accomplish that. 3k or so for the exh brake, programmer and some new wheelz would get you mostly there except in the power department. The rest of the truck is already built to handle whatever you can throw at it.
Last thing, how many miles, how many miles on injectors, and do you have additional fuel filtration? That is the most important thing to look into IMO on 3rd gens.
A lot of owners, myself included only get 100-150k on OE injectors without additional fuel filter. OE filter is not up to par. 2micron add on kit is $200 if you buy one manufactured, or about $50-100 if you make one. Either is worth it....today.
Jul-15-2018 12:59 PM
Jul-15-2018 10:13 AM
Jul-15-2018 09:14 AM
Jul-15-2018 07:33 AM
Jul-15-2018 06:56 AM
Jul-14-2018 09:36 PM
Jul-14-2018 09:05 PM
