โNov-03-2014 02:51 PM
โNov-11-2014 05:37 AM
โNov-11-2014 05:11 AM
โNov-10-2014 03:33 PM
I believe my issue is a bit more severe than a little moisture. Not only is the insid a bit wrinkled.....when i stow the door in the up posituon, rusty water runs down the door. Not much, but enough to worry me.
โNov-10-2014 10:56 AM
โNov-10-2014 10:55 AM
camp-n-family wrote:
Door to the outside of the frame is 31 1/4w X 17 1/4h. Door itself is 29x15. Hinge is 23 1/2. It looks like I have a little bit of that waviness on the inside too. It's just wall paper covering which could get like that from moisture and humidity I think, no signs of water getting in.
โNov-04-2014 07:42 AM
โNov-03-2014 07:05 PM
I have a 2013 31BHPR but it is in storage down the road. I can swing by tomorrow and measure if nobody else can before then.
Mine has never leaked at the storage doors but I do get a bit of water that sits in the bottom of the frame where the screws are. I saw that as a potential leak so I covered the screw heads with silicone caulk. Is the wavy bit of the panel at the top or bottom of the door? One thing I found odd is that there is no caulking around the door panels and the frame it sits in. You'd think water would get in between there and damage the doors like you see. I considered caulking each of the doors for this but mine seem to be fine.
The drip cap looks like a potential fix but could you still fully open the door and use the latch once it's installed?
โNov-03-2014 03:37 PM
