2012 Silverado 2500 CC Std Bed Duramax 4WD
L3
Hi All,
Looking at a tow vehicle and considering this 2012. Hoping some of you have this truck or similar and can give me your opinion. Been a good tow vehicle for you? Also, what are you pulling with it?
Thanks!
17 REPLIES 17
N-Trouble
My SLT crew has no back door storage
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
ksss
I have storage in both doors (crew cab), its an LT trim.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
N-Trouble
My biggest gripe with my interior is not the lack of โ€œblingโ€ but the lack of useable storage. It was just not well thought out in this regard. Hell you cant even store anything in the back doors. Would have cost another $2 to form some storage pockets into the doors but some bean counter must have said no.
ksss
What I have come to appreciate in the GMT900's is the interior. Not that it is all that nice, but what it misses in bling, it makes up for in durability. At 140K I have had to replace one vent actuator. My 800's while more comfortable and prettier, were not as durable. I like that it ages almost without signs of wear. Only the black wearing off the fan speed button, and a shiny steering wheel is there any indication that it has that many miles. The seats are just as supportive and intact as the day it was delivered. Mechanically this 08 has never missed a day of work. Just a solid rig.
2013 Fuzion 342
2011 RZR Desert Tan
L3
Yeah, noticing the Silverado 2500 and 3500 isn't much different. Rear spring is different changing payload rating? Pulling specs from VIN says 15,800 max fifth wheel/4175 hitch weight. Seems contradictory to their published GVWR. Guessing my camper could be closer to 13,500 loaded with a pin weight of 2500 - 3000. So looking at GVWR the truck doesn't have the payload capacity. If you do the math on weight of the truck compared to axle ratings, plenty of payload. And well within the rating for fifth wheel towing. Crazy. Still think this truck would handle it fine.
Grit_dog
Navigator
Navigator
Or you'll be fine because it's identical to a 3500 minus a little rear spring rate. (Not as much as the gvw appears to indicate either.)
N-Trouble
sayoung wrote:
LowRyter wrote:
IIRC, my 04 DMax is rated at 15k for 5th wheel. 12.5 for bumper pull.
My 03 2500 CC longbed was 15k for 5er & pulled/stopped our trailer fine. I think the 2012 2500 is 17000 on 5er.
Dont read too much into those 5er ratings. Youโ€™ll be way over payload ratings with a 15klb 5er.
Grit_dog
Navigator
Navigator
Yup, good truck. Best combo for a diesel that year IMO. Standard used vehicle concerns or inspection notwithstanding.
sayoung
LowRyter
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Ducati 939 SS, Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
L3
Thanks for the input. So far sounds like a solid truck. Hope to check it out this weekend. N-trouble, I intentionally left my camper out of it. I want opinions on the truck itself not what everyone thinks it could/should pull. Of course me asking what people are towing with it kinda opened that door anyway. ๐Ÿ˜„ 5th wheel rated at 12,500 lbs loaded is what will be behind it.
sayoung
L3 wrote:
Hi All,
Thanks!
I have a 2012 CC dually 4x4. I pull a 35 ft Jayco , no issues. When I was a business owner I have pulled gooseneck trailers with our material to my job site with close to max ball wieght of the gooseneck hitch. Not advocating doing this but sometimes stuff happens
Only trouble had to replace the egr valve also the def sensor gave up, both warranty.
N-Trouble
L3 wrote:
Hi All,
Thanks!
More importantly how about telling us what you plan to pull with it?
N-Trouble
Second Chance wrote:
We had a '13 Sierra 2500HD Duramax/Allison. Great tow vehicle, but you are limited with payload on a 3/4-ton truck (even less payload with the diesel and 4WD). We moved up to a 1-ton for our 14K (3,000 pin weight) fifth wheel to be within the rear axle limits on the truck. Loved the Duramax, though.
Rob
GM 3/4 and 1-ton trucks share the same axle.
