2013 Ram 1500 tire pressure
jsmitty2100
Can anyone give me some insight on what I should be running my tire pressures at while towing my travel trailer. I know cold inflation under normal conditions is 40psi. I thought I saw a chart somewhere that showed what loaded tire pressure should be, but can't seem to find it. Any help is appreciated.
8 REPLIES 8
GordonThree
doubled post
GordonThree
mileshuff wrote:
40 PSI is below a load C rated LT tire. I assume you have a lighter tow vehicle and trailer doesn't have a high hitch weight?
The topic is for ram 1500, not the HD series. The Holy Sticker from my grocery-getter Outdoorsman.
mileshuff
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
GordonThree
No need to run the max pressure. 2013, why have you replaced your tires already, that the sticker is no longer applicable?
My 13 came with range E tires for some reason, the sidewall is 80psi, which is ridiculous for the light weight of the truck, it would be like driving on stone tires.
Mark_Heisler
that right
different tires have different max tire pressure
that sticker is only for what tires came from the factory on your truck
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
jsmitty2100
Ok, go by what the tire says not the sticker on the door for towing?
rhagfo
Mark Heisler wrote:
only put what the max cold pressure on your tires says
X2
If towing.
Mark_Heisler
