Nov-23-2019 01:25 PM
Nov-27-2019 06:41 AM
Nov-27-2019 06:28 AM
Nov-27-2019 05:06 AM
blofgren wrote:
I suppose it depends on how long you intend on keeping the truck. If only a few years where most of them are under warranty then the CP4 pump is likely less of a concern.
Myself, I plan on keeping my truck for a very long time (likely until death do us part) so the long term cost of ownership and repairs was important to me. I just couldn't bring myself to chance playing Russian Roulette with the CP4 when at the time there were perfectly good trucks with the trusty CP3 (the Ram/Cummins used the CP3 until the new 2019 models came out).
Nov-26-2019 07:05 PM
Nov-26-2019 10:20 AM
Nov-26-2019 10:06 AM
Nov-26-2019 08:18 AM
strikeu wrote:
Grit Dog and Travlingman,
I don't know what you're looking for as for "data". I had some other pages that I closed out where between the ones I posted and the others, there was enough data to make a trend in my opinion.
I would love to see the number of Powerstroke engines sold from 2011-2017, how each was used, the number of failures of each part, the number of miles each engine had on it at the time of failure, and finally the cause and remedy of each failure...however I seriously doubt that is available to just anyone. if thats what you are asking me for, I don't have that.
However I do NOT find the amount of data regarding the RAM engines with this part, as I do the Ford Powerstroke.
my turn to ask you where you see that Cummins is putting the Eurpoean made Bosch CP4 fuel pump on it's engines. I have one in the driveway but it's dark and cold right now, I will go out and see if I can tell in the AM
Nov-25-2019 05:22 PM
Nov-25-2019 08:11 AM
strikeu wrote:Grit dog wrote:
Well, what did you hear strikeu?
We all love rumors, conjecture and facts. Seems typically in that order as well. Lol.
the High pressure fuel pump fails a LOT in 2011-2017 6.7L powerstroke engines. there is a great many people trying to start a class action law suit on that issue. that particular fuel pump was made in Great Britain where the diesel is more "oily" than American specs. so when it runs with American standards diesel it disintegrates for lack of lubrication. it can destroy an entire engine to the tune of $10-15k.
it seems (no real data yet) that after 2017 there is a different fuel pump...so thats good if I am buying new, but not good for my 2012.
the next high fail item is / was the turbo. new turbo kits can be obtained but it seems the original turbo on the powerstrokes are some type of Rube Goldberg contraption that fails routinely. new turbo kits are ~$3k. this seems to be fixed in the 2015+ models,
bottom line is the 2017s are a bit too new to gather any real failure trends, but there are some significant data for the 2011-2017 6.7L powerstrokes. SO much that I am leaning back towards the RAM 3500.
strikeu wrote:
here is some of what I found. I closed the pages, so some simple searches will probably yield the same results
https://www.classaction.org/ford-diesel-fuel-pump-problem-lawsuits
https://www.claimspages.com/news/2018/11/28/classaction-lawsuit-proposed-against-ford-motor-company-for-6.7l-cp4-fuel-pump-failures/
https://www.littlepowershop.com/ford-6-7-powerstroke-diesel-common-issues-problems-and-fixes/
google powerstrokenation.com and look through the blogs. there is a TON of info on failures there. that page has a lot of pop-up ads so I have going there for long.
Nov-25-2019 07:36 AM
Nov-25-2019 07:32 AM
ACZL wrote:
Ford I believe had Nox sensor issues thus extended warranty for years '11-'14 (I could be wrong). My '15 F350 was problem free when I traded it w/ 30K miles. My '17 F350 DRW also had the block heater cord replaced along w/ the DEF heater. Now I have a Nox sensor issue which Ford is trying to deny it's bad because their data says "That use of aftermarket fuel treatment can cause problems". It's been back to dealer 2x w/ same problem, going back for 3rd time tmrw. Funny thing here is, had DW take it to a dealer near her workplace and they said they couldn't fix it because they wouldn't get paid for it due to another dealer already having diagnosed it. Some warranty thing.
Nov-25-2019 06:44 AM
Nov-25-2019 06:25 AM
Nov-24-2019 03:21 PM
Nov-24-2019 03:13 PM
