Dec-01-2017 09:21 AM
Dec-05-2017 10:40 AM
Dec-05-2017 10:37 AM
1stgenfarmboy wrote:AllenTC2 wrote:1stgenfarmboy wrote:
Allen, If a nice smooth ride is important to you and your wife I would consider going a little smaller so a well equiped 1/2 will tow it easily, towing with a truck that is maxed out will take some of the fun out of it, and having a 3/4 or 1 ton truck to drive around unloaded everyday is not fun.
Wait......I have to have a wife!?!? :E :B
OOooooooooo..............significant other..........? ? ? ?
:h
Dec-05-2017 10:21 AM
Ralph Cramden wrote:Huntindog wrote:
As far as the current discussion about half ton capability.What is missing is the durability of the half tons vs their heavier duty siblings.
Despite being true, good luck getting that point across to many on this or any other RV related board.
Dec-05-2017 10:00 AM
But on the other hand, if I had an Excursion, or a 250 Van, with appropriately the same weight and wheel base, it's isn't an issue.
Dec-05-2017 09:56 AM
Maury82 wrote:
I know that the HDPP has stiffer springs and beefed up front and rear suspension. If you want to provide useful information doubting the ability of the truck, why not put up a challenge on whether that HDPP, beefed-up suspension is enough.
Dec-05-2017 09:18 AM
TomG2 wrote:LOL I'm happy with the 9000lb FW but not with the 9000lb TT
So, what is the score so far? How many are happy with the performance of their half ton pickup towing in excess of a 9,000 pound travel trailer? Any disappointed? Anyone actually towing over 12,000 pounds per the advertised rating?
Dec-05-2017 09:17 AM
Dec-05-2017 09:01 AM
goducks10 wrote:Maury82 wrote:2112 wrote:Maury82 wrote:Sorry, it's in my sig
I read your testimony, and I know how much your trailer weight, but you skipped out all pertinent information about your 1/2 ton truck...why leave that out?
It is testimonials like yours that doesn't help a newbie like me at all, and is why I'm putting my money on the manufacture's claims, and not based on these testimonials.
I believe the manufacturers are probably stretching their numbers,and it is why I would not tow at over 80% of a truck's ratings, whether it is a 1/2 ton or a 1 ton.
What year was your truck?
Motor?
Rear end ratio?
Payload?
Towing ratings?
We're you towing over 80% of towing/payload rating? Those are very important information that you left out.
2011 f-150
3.5L EB
3.73
2084
11,300lbs
Timbren's helped a lot with sag and stability
We're you towing over 80% of towing/payload rating? Darn close if not a little over 80%. I didn't get a chance to weigh it. It was stolen to become a meth lab.
If the numbers were the same on a 25' low side trailer it most likely would have towed much better. I have no problem towing a utility trailer, car hauler with a tractor etc.. A 35' high side TT changes the game.
Thanks. My settings are not showing any signiture information.
You were ~ 80% on the tow ratings.
My trailer is also 37 ft, 8,300 lbs dry, and I will also be at around 9,000lbs. It is just me and a girlfriend at times, and besides a 50lbs inverter generator, the heaviest single item I'm likely to carryou would be the the two 30lbs. Propane tanks.I doubt if I carry any more clothing than I do in the trunk of my Honda...maybe some tools.
My RV is for vacations for a few weeks, tailgating at homecoming, and attending out of town festivals and events.
With the added capacity of the 2018 I'm looking to get, I should be in the 72-75% towing range (12,500lbs plus), and approximately 50% of payload ratings.
And with the lighter weight of your 2018 you'll be in the same boat as those with a softer sprung F150. The tail wagging the dog syndrome. The worst thing to do is make a tow vehicle lighter and the trailer heavier. Live and learn.
Dec-05-2017 08:55 AM
BarneyS wrote:
You are all aware, I hope, that the "V-5" shown in the picture above is not the class of that hitch. It is the document version of the testing standards that the hitch meets.
The "class" is determined by the weight numbers shown and that varies between different manufacturers.
Here is one manufacturers version.
Here is another.
Here is a third version by a retailer.
And a forth version.
Barney
Dec-05-2017 08:29 AM
Dec-05-2017 07:58 AM
Dec-05-2017 07:47 AM
V-5 is a testing standard, not a Class.
A Class III hitch is rated at Class III by way of the V-5 testing standard.
The V-5 testing standard is now obsoleted, but those interested in comparing hitches should be aware that V-5 is only a testing standard, not a class rating. Most OEM hitches (up until the recent adoption of a new SAE standard) had "V-5" on the label, regardless of weight Class rating. The V-5 simply signifies that the V-5 standard of testing was used to determine the Class rating.
Incidentally, there is no such thing as a Class V in the V-5 testing standard. The highest class rating in the standard is Class IV. The use of the term Class V was a marketing ploy initiated by Reese, that later became a colloquialism for any hitch rated higher than the ratings defined as Class IV.
Specifically, "V-5" is simply a short hand acronym for the Vehicle Equipment Safety Commission Regulation 5, or VESC-5, or V-5. This federal commission was convened by the US Govt in the 1960's to address the lack of standards on the ratings of automotive towing equipment. In 1968, a final regulation was adopted, which was later revised in 1973 and 1977, and was later supplemented in 1980 by VESC-19, or "V-19", pertaining to fifth wheels and gooseneck trailers. Similar standards were commissioned by the Society of Automotive Engineers entitled the SAE J684, first issued in 1938, and more recently revised in 1998 and 2004. Some hitch receivers will say SAE J684 on the label instead of, or in addition to, V-5. Again, these symbols do NOT indicate a "Class V" weight or capacity rating, as no such rating exists in either of those standards.
The SAE standard was further supplemented with SAE J2638 pertaining to gooseneck and 5th wheel trailers, and was more recently revised with the towing testing standard that has been in the news during the last five years as the big three play chicken with each other as to who will adopt the new standard first or last, as the newer standard is more stringent, often yielding much lower tow ratings on the same equipment.
Dec-05-2017 07:41 AM
Dec-05-2017 07:40 AM
Here is another.
Barney
