2020 Silverado 1500 Duramax and the Ike
FishOnOne
The Silverado did extremely well with the exception of brake applications compared to the Ram Ecodiesel. Just a reminder that the Chevy has a exhaust brake and the Ram doesn't.
Enjoy...
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
19 REPLIES 19
SidecarFlip
Quit watching the 2 buffoons in a truck a while ago.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
larry_barnhart
ScottG wrote:
I know they're trying to do these test equally between all makes but it would have been interesting to see what happens if he manually downshifted - if that's posssible.
Seems possible to have gone down a couple of gears and this is what most drivers would do for sure. Test don't show everything.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Yes this was supposed to be the Super Ike which means they tow the max rating of the truck. I don't know the specs but it sounds like the Ram Eco Diesel has a higher tow rating than the Chevy Duramax.
ScottG
ib516
I think when they tested the EcoDiesel, it was towing significantly more weight.
Don't know why they can't keep the weights the same to make a more accurate comparison.
In any case, that I6 Duramax seems like it performs very well. Time will tell if it was an engineering success or failure.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
