โAug-26-2014 05:08 PM
โAug-30-2014 08:46 AM
โAug-30-2014 06:57 AM
dadwolf2 wrote:
... snipped ... what kind of tongue weight are you expecting? ... Also, don't forget that your hitch receiver doesn't have to go all the way to the edge of the camper, by the time you put the trailer ball in, that extends the pivot point back another 8-9". I still added chains and forged turnbuckles from extended hitch to frame for added strength.
โAug-29-2014 05:55 PM
mkirsch wrote:
The thing about extending the receiver is there are bolt-on solutions out there.
Not so when extending the trailer tongue. You need custom fabrication.
Reality Check has piqued my curiosity on the tongue extensions. Do you have any pictures you could share?
โAug-29-2014 02:51 PM
โAug-29-2014 02:16 PM
โAug-29-2014 07:49 AM
โAug-28-2014 05:15 PM
Mello Mike wrote:
If you're towing a heavy load with a heavy tongue weight then I would buy a Torklift Superhitch. However, if you're going to tow something light or tow a vehicle 4-down then a simple 2 ft hitch extension will be more than sufficient.
โAug-28-2014 05:01 PM
bigfootford wrote:joe b. wrote:
Instead of using an extension, I have seen RVers extend the trailer tongue, to the needed length. Recently I was looking at a posted blog where a couple took their TC round trip from Michigan to Alaska, pulling an enclosed cargo trailer with a motorcycle in the trailer. He had the trailer tongue extended and said it all work fine for the trip.
I can totally jack knife this trailer 90 deg and not touch the camper.
We added 1.5 ft. Basically duplicated the tongue on a Uhaul 5x8 single axle trailer except for the bend upward. 3/8" 2x3 tubing.
Jim
โAug-28-2014 04:26 PM
wcjeep wrote:AISURFFISH wrote:
The good thing with the super hitch on s ford is....it fits 99-2015.. I have put it on each truck I have owned.. I have had 3 trucks and 4 campers.. 1 SUPERHITCH..
That seems like cheating. Congrats.
โAug-28-2014 03:56 PM
โAug-28-2014 08:10 AM
โAug-28-2014 07:40 AM
โAug-28-2014 07:23 AM
โAug-28-2014 07:22 AM
โAug-28-2014 06:46 AM
sonuvabug wrote:
That SuperHitch is super pricey. What about a 24" extention with "loops or brackets" welded into the sides such that load binders could be secured from each side of the extension back to the main hitch?
