Nov-17-2018 09:55 AM
Nov-20-2018 04:02 PM
Nov-20-2018 03:00 PM
Nov-20-2018 02:26 PM
goducks10 wrote:
It's my understanding that you can't get anything but 4.10's with the 6.0 GM
Nov-20-2018 12:35 PM
TundraTower wrote:
Before there's any more insults, the Tundra is the nicest, best performing, best handling, most reliable truck I've ever had. I bought 7 new chevy's over 33 years and finally gave up on their quality and went to Toyota. Never had a problem and it's done everything we've asked it to do, including pulling that trailer over the continental divide 4 times.
This is the most un-excited I've ever been about trading vehicles. But we need more capacity and Toyota doesn't make a 3/4 ton. If they did, I'd already have it.
I was concerned about gas mileage because the 3/4 ton itself weighs 1200 lbs more than the tundra, has less HP (360 vs my 381), and has a taller gear ratio (4.1 vs 4.3 in the Tundra). All of those numbers are going in the wrong direction for power and gas mileage.
Nov-20-2018 08:59 AM
TundraTower wrote:
Monday we are going to try out a 3/4 ton gas Silverado 3/4 ton, 4.1 axle ratio, 4WD. Going from a Tundra because we've run out of GVWR on the truck (because we take too much stuff).
We get 8-9 MPG in the Tundra towing 8K lbs. What kind of gas mileage is anyone getting in the 3/4 ton gas Chevy's or GMC's with similar gear ratio --- solo and towing ???
Thanks.
Nov-20-2018 07:23 AM
Nov-18-2018 09:27 PM
Nov-18-2018 07:32 PM
Nov-18-2018 06:27 PM
Nov-18-2018 05:00 PM
Nov-18-2018 10:43 AM
Nov-18-2018 09:08 AM
Nov-18-2018 08:32 AM
Nov-18-2018 07:42 AM
Dave H M wrote:ppine wrote:
If you want a rig to pull something, why not get a real 3/4 ton or better yet a one ton? Why not join the winning team and get a diesel?
I get 23 mpg empty, 18 towing a 19 foot boat and about 13-14 towing a TT. The engine is not even working hard.
This has been a pretty decent thread.
I learned some new terminology (turd)
And it did take a while before a typical diesel owner reply appeared without a hint what so ever concerning the OP. :S
Nov-18-2018 07:09 AM
