5th wheel clearance
DickOK
We just bought a new truck and hitch. Our 5th wheel when hooked up sits level. However, there is only 4 1/2 inches of clearance between the 5th wheel and truck. Hate to raise the hitch which will make the 5th wheel not sit level. What do you think about the clearance?
Dick OK
10 REPLIES 10
Cummins12V98
Set it to 6โ€ min. Go to the scales weigh each axle. Be sure you are not overloading rear axle.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
agesilaus
joelc wrote:
I have a 2006 Ford 6.0 Lariet and a Carriage Cameo. Because the truck is so high, Carriage, when they were in business and I ordered the RV, flipped the axles on the 5er. This gave me the clearance I needed. Don't know if all RV can be done on all 5er's or what the charge would be, but you can check with a dealer you trust to find out if this can be done and would solve your problem.
It's a lot easier to adjust the hitch first, until you run out of hitch adjustment then move on to more extreme measures like flipping the axle.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
joelc
schlep1967
Lower the pin box one hole. Like others have said, a little nose high will not hurt. That is why they put "flexible" suspensions on the trailers.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
BB_TX
6" is better. Running a little nose high is not a problem.
agesilaus
5 inches is usually considered to be the minimum, 6 to 8 inches is better. Adjust the hitch.
Superbumper
Lwiddis
โ€œpretty tight especially if you get a bit off the beaten path.โ€
Even a gas station driveway might cause an expensive problem.
Super_Dave
An inch to 1 1/2" nose high is nothing to worry about, raise the hitch.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
IdaD
Can you lift the trailer? 4.5" is pretty tight especially if you get a bit off the beaten path.
2015 Cummins Ram 4wd CC/SB
twodownzero
I don't think that's enough clearance. I lowered my truck 2" in the back to deal with this problem. What kind of truck is it and is that an option for you?
