A/C Condensate on Roof.
Jack_Hart
This time of year the A/C gets run a lot here in Florida. It's humid and condensate flows like a waterfall off the roof right over my camper door. Has anyone come up with a neat and easy way to channel water off the roof so that it doesn't end on doors or windows or inconvenient locations?
5 REPLIES 5
mkirsch
Nomad II
Nomad II
X2. Doesn't take much and you won't notice being 1/2" out of level unless you've got some Princess and the Pea thing going on.
Kayteg1
Tilt the camper slightly on the side, so the water will drip in the corner.
2oldman
I ran a bead of caulk on the roof, and also try to have the front slightly higher so it runs off the back.
JIMNLIN
as suds mentions stick on...... I added 32' on each side of my current trailer 15 years ago eze gutter.
For whatever reasons the trailer mfg didn't add any type of drip rail. Still stuck tight after 15 years. Good stuff.
54suds
use this self stick rain gutter e bay link to channel the run off
2021 Chev 6.6 duramax ltz DBL cab,drw,4x/torklift tdn's,
1999 Bigfoot 1011
