AC leaking into the rv
harper223
So I tightened the gasket bolts, not too much and ran the ac. After about 10 minutes water started flying out of where the blower motor is (I had the inside cover off while watching). This is the only place water has ever leaked into the TT. I think the gasket is good. I think the tightening is fine. I'll check for drainage debris on the roof tomorrow, but if none is there what else should I check?
"Whatever is good to know, is difficult to to learn."
5 REPLIES 5
allen8106
It's possible the indoor coil is freezing up. this can be caused by a couple things. To little air flow. Check your filters and make sure they are clean. Could also be caused by a freon leak. An under charged system will freeze up the indoor coil and drip water to the interior. Pull the cover off the inside and look up inside the unit to see if the indoor coil is frozen up.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
rockhillmanor
I sadly paid an RV Mobile Repair to find out that all I had to do was 'unlevel' my RV a bit so the water did not sit on the roof. ๐Ÿ˜ž
Mike_Taverniti
Similar issue with mine when new. Found AC over tightened and seal smashed causing drains to be against roof and not able to function.
pipefitr
Sounds like the drain is blocked up and the pan is overflowing. You have to pull the cover off and clean the drain pan.
Paul
harper223
So it was thinking that the rv may be too level.... no water to really travel anywhere. I'll jack it up about an inch tomorrow and look for drips in the rear off the roof.
