โJul-22-2013 04:17 AM
โJul-23-2013 10:32 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โJul-23-2013 09:21 AM
Reddog1 wrote:
I am not an electrician, but have done lots of residential wiring. I do not think that wire is used. As I recall, years ago the wire was connected to the gas pipe. I think it is no longer done that way. My TC is a 1988, and it does not use that ground wire. It does use the three wires from the extension cord, as does yours. Black is hot as yours is now wired. It connects to the service bar that feeds your breakers. White is neutral and connects to the other white wires at the terminal block. The ground (copper non-insulated) connects to a block with all other copper wires. The copper wire hanging outside is no longer used. to be of any value, it would have to be connected to a ground rod eight feet long, driven in the ground, or equal. Personally, I would disconnect it from the propane line. That is probably why it was cut off.
I think you are wired correctly now. Do you still trip the breaker? Do you know if the receptacles in the TC have the correct polarity?
Wayne
โJul-23-2013 09:00 AM
Toad: 91 Zuke
โJul-23-2013 06:35 AM
โJul-23-2013 04:53 AM
โJul-22-2013 06:50 PM
ticki2 wrote:
That's the one .
โJul-22-2013 06:20 PM
โJul-22-2013 05:36 PM
ticki2 wrote:
Yes that wire is the issue . The disconnected black wire belongs in the single screw lug near the top right of the breaker . NOT on the white wire bus .
โJul-22-2013 05:32 PM
cruthas wrote:
Could this be the issue?
Looks like the black wire is completely disconnected from the breaker box. I imagine it should go back in the top slot? There is a white wire in the top slot already, however....
โJul-22-2013 05:00 PM
โJul-22-2013 04:47 PM
Toad: 91 Zuke
โJul-22-2013 04:33 PM
โJul-22-2013 10:46 AM
Toad: 91 Zuke
โJul-22-2013 09:49 AM
Reddog1 wrote:
My bet is it will be very simple when you find the problem. Finding it may not be so simple. :B
You have not commented on my suggestion of using an Ohm meter. This suggest to me you have not used one. I really encourage you to look into Ohm meters, they can be your best friend. The basic use will be of great value to you. If you have access to Harbor Freight, the meter is as cheap as $3 on sale. It also has a volt meter, AC and DC. A very valuable tool, even in the cheap (inexpensive) versions.
