Jul-13-2017 07:39 AM
Jul-14-2017 10:19 AM
SideHillSoup wrote:
Aluminum welds just don't stand up as good as steel welds in our case. Now because the truck suspension is taking the beating you might be ok.
Jul-14-2017 10:08 AM
Jul-14-2017 08:30 AM
Jul-14-2017 04:33 AM
jimh425 wrote:SidecarFlip wrote:
MIG is speed, TIG is always quality.
Probably if you are welding it. It's certainly possible to do TIG wrong.
Jul-13-2017 09:29 PM
Jul-13-2017 07:18 PM
Jul-13-2017 05:20 PM
jimh425 wrote:
I don't think any methods hold up better than others. They simply have different sets of problems to deal with. Whatever model you buy, make sure you have adequate defense against water and take care of it.
Four Wheel Campers has been around 30 years, but not under the same ownership. http://www.fourwh.com/popup-truck-camper-history/
Airstream isn't the original company either. Oh, and not all aircrafts are still in service either if you want to consider aircrafts as "it". Finally, MIG is common for aviation. Again, if you want to consider aviation as "it", you should look for a MIG welded model. 😉
Jul-13-2017 03:21 PM
Jul-13-2017 03:10 PM
SidecarFlip wrote:
Winder how long Four Wheel Campers has been in business. They have always had TIG welded (not bird poop welded) frames.
Jul-13-2017 03:04 PM
Jul-13-2017 12:39 PM
Jul-13-2017 12:30 PM
Kayteg1 wrote:
From my research aluminium frames come on the market in 2002-2005 depends on the brand, so I would scratch all older models.
Jul-13-2017 09:14 AM
Jul-13-2017 09:10 AM
