aerodynamics
campingguy62
Would the Forest River Flagstaff Micro Lite 21 FBRS be considered to have good, fair or poor aerodynamics?
20 REPLIES 20
Francesca_Knowl
PawPaw_n_Gram wrote:
facory wrote:
Wow!! Have never seen a trailer like that. Looks like it came our of Star Wars.
It's from "A long time ago in a state far, far away......."
Yeah...California in the 1930's! :B
Here's a link to the video the pic came from.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
PawPaw_n_Gram
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
facory
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
69_Avion
The Airstreams, Avions, etc. do make a big difference in the way they tow. It isn't all measured by mpg, but by the way they handle. The low center of gravity and decent aerodynamics make them stable, even at higher speeds. They don't sway as much in cross winds and tend not to be affected as much by passing semi trucks. I have towed plenty of trailers and the rounded aluminum trailers seem to tow the best and the higher the speeds, the more noticeable to difference is.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
Francesca_Knowl
sushidog wrote:
Aerodynamics is a simple formula. CdA which is its drag coefficient times its frontal area. Both matter. My Aliner is basically a proverbial brick, so it has a poor Cd, but it has a small frontal area. In the other direction an Airstream has an excellent Cd, but a large frontal area. Most TTs are the worst of both worlds. Even those with a rounded front end have a barn door flat rear end creating lots of drag. Adding Air Tabs helps, as will a tail cone. But reducing the frontal area, like a HiLo or a Trailmanor is even better. A pop-up teardrop would be the best solution if anyone would build one.
Here's a scalable concept I drew up years ago.
Chip
sushidog
The aerodynamics of the TV also make a difference. Here's my idea of a pop-up wind deflector for a pick-up bed topper - to direct air flow over a boxy TT. Triangular side walls will also pop-up. I plan on building this one for full-timing use.
Chip
1999 National Tropical
Triton V10, Ford F53 Chassis
PawPaw_n_Gram
If you can improve mileage by 1 mph - that's a 12.5 to 10 % increase for most folks.
Truckers would kill for 10%.
Some very scientific studies have been done on automobile windshield shape. 30 degree slope reduces resistance on the windshield about 25%. The winds shield still have to move all of air pressure out of the way at that speed.
The way we tow, and the speeds we drive have a greater impact. Changing your cruise speed from 70 to 62 will normally gain you more mileage increase than aerodynamics. It takes approx. 27% more power to go 70 mph than 60 mph because of the resistance of the air being moved out of the way.
Weight does have an impact - very small unless you are in mountains with a lot of uphill driving.
Smarter driving is the best thing most of us can do to improve fuel mileage.
Andy_F
aftermath wrote:
The aerodynamics of a trailer really does make a difference. I can't quote actual numbers here like others will since I don't know if you save 2 or 3 mpg or not. But I can tell you of my experience. I used to pull a 21 foot hybrid with my current truck. I changed to a 25 (actually 26) foot Airstream. Using the same truck, going the same places, packing the same equipment and traveling the same speed I found that my mileage did not change. Even though our current trailer is 5 ft longer and 2000 pounds heavier, we get the same mileage. The only other variable here was the shape of the trailer.
Some people question what a few hundred extra pounds will do to their mileage. The extra weight of the water or equipment is a minor issue when compared to the size and design of the frontal area of your trailer.
x 2 based on our experience. We towed a 23 foot Rockwood hybrid shaped mostly like a brick. We went to a 30 foot TT with some aerodynamics to it and it tows much better. The wide stance axles also make a difference but I'm convinced shape does matter.
Andy
2018 Tiffin Allegro Open Road 36LA
2012 Keystone Bullet 281BHS-Sold
2008 Toyota Sequoia-Sold
ProPride 3P - what a hitch!-Sold
Nights camped in 2017=42
Nights camped in 2018=32
Nights camper in 2019=30
Nights camped in 2020=17
facory
IMHO: More importantly is the protection built into the front of the trailer. So many new trailers have the fiberglass shell unprotected from road debris. It only takes one rock, or something else left on the roadway, to punch a hole through or crack the fiberglass shell. What I look for is the diamond plate protection. I have it and can tell you it has saved my trailer from serious damage on more than one occasion. I would not purchase a trailer without this protection. Period! Aerodynamics is a non issue with today's trailers.
W_E_BGood
An interesting article from RVlifestyle from several years ago.
And while this discussion is about semi trailer aerodynamics, I would think a lot of the principles still apply to travel trailers.
And one more technical (read: scientific, not opinion) discussion on semi and trailer aerodynamics with an imbedded youtube video of the Dassault System's computer program.
Hope this helps. Regards, BGood
thomasmnile
Traded an 10000 lb. plus fifth wheel for a Jayco WhiteHawk that weighs about half as much. Took the WhiteHawk on an extended trip for the first time last month (320 mile trip to Fl. Panhandle mostly on Interstates). I was shocked the fuel mileage I was getting (3500 Ram diesel) was no better/slightly worse than towing the fifth wheel. Apparently the airflow over the truck cab, through the bed, and into the sloped nose of the TT produces quite a bit more drag. Fuel mileage to the Panhandle 10.6 mpg, trip home 11.6 mpg (driving on cruise @ 60mph except for about 60 miles driving on secondary roads both legs of the trip). So yes, a towable RV possesses the aero properties of a brick.
aftermath
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Francesca_Knowl
ROBERTSUNRUS wrote:
beemerphile1 wrote:
A little better than towing a barn behind you. :B Good aerodynamics and RVs don't really fit well in the same sentence.
๐Ÿ™‚ Hi, some do!
:R
Yeah...popups!
ROBERTSUNRUS
๐Ÿ™‚ Hi, some do!
๐Ÿ™‚ Bob ๐Ÿ™‚
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
