โSep-03-2018 03:23 PM
โSep-07-2018 06:00 PM
โSep-07-2018 05:59 PM
wanderingaimlessly wrote:
Not knocking either one, but I bought a small inflator from Lowes that seems to work well for my Truck.
https://www.lowes.com/pd/Kobalt-12-Volt-120-Volt-Car-Air-Inflator/1000092575
Quicker and quieter than my last one, works on either 120 VAC (faster) or 12 VDC, and can be set for a given pressure and will shut off.
โSep-07-2018 05:57 PM
theoldwizard1 wrote:
I just bought a Milwaukee M12 inflator. Great little inflator. Perfect for "topping off" tires and blowing up inflatable toy. Max pressure is 120 PSI. For large tires (like Class A's) it would take a long time to fill a completely flat tire. Likely 3 or more batteries (M12 lithium ion).
The best feature is, just screw it on (brass Schrader valve adapter), set the pressure on the digital gauge and press start. As I said, you had better have 1 or 2 spare batteries and a way of recharging them when you are on the road.
TIP : You need to make your own adapter to fill large inflatable toys. But a 3" grass tire valve (cheap on eBay). cut off the end where it would normally attach to the rim. Deburr inside and out. Mini blow gun !
โSep-07-2018 12:09 PM
jefe 4x4 wrote:
Via Air 440.
jefe
โSep-06-2018 01:16 PM
โSep-04-2018 10:48 AM
โSep-04-2018 09:56 AM
โSep-04-2018 09:51 AM
โSep-04-2018 08:32 AM
โSep-04-2018 07:49 AM
โSep-04-2018 07:47 AM
โSep-04-2018 07:46 AM
โSep-04-2018 07:08 AM
โSep-04-2018 05:59 AM
