โOct-07-2015 08:04 PM
โOct-10-2015 07:28 AM
wannabervin wrote:
I'm thinking about doing my own winterizing this year. I'm also planning to resurface my deck at home. Each job raises the possibility of purchasing an air compressor. But I know very little about air compressors. Can one air compressor be powerful enough to drive nails but also be dialed back to blow out water lines in my TT?
โOct-09-2015 11:53 AM
myredracer wrote:
I use a Porter Cable pancake compressor as in the photo and it works great. I set it to 50 psi for blowing the lines out. The system is good for at least 100 psi and you can go higher than 35 psi. I have our Watts regulator set to 60 psi. If you use a blowout plug like in the 2nd photo it makes it easier too as opposed to the tire valve type. Just set the regulator to the pressure you want and take your time inside getting the water all out.
I have a 60 gal. 3 cylinder compressor but is waaay overkill for the TT. I am planning to install a 12 VDC Viair compressor in the TT and will use that if it can blow enough air but I doubt it will come anywhere close enough.
As mentioned above, once you've used air, you'll never go back to antifreeze.
Now I am getting depressed thinking about this... Spring is right around the corner tho.
โOct-09-2015 11:16 AM
โOct-09-2015 07:33 AM
โOct-08-2015 06:58 PM
โOct-08-2015 06:04 PM
rbpru wrote:
Perhaps the biggest problem with the compressed air approach is you have to know the plumbing layout in your TT.
If you open the low point and blow out each individual faucet chances are you will drive the water out of the lower point. However, there is no guarantee that there is not some point in the system where the water line tubing sags creating a gathering point for the water droplets left in the pipe.
My TT water system is rather simple, the kitchen sink, bath sink, tub, shower and outside tap are all within 10 feet of the low point drain and I can remove various panels to check for sag points. Others are not so simple.
Still, after I have blown the pipes, I hook the pump input to a bottle of anti-freeze and pump it through to each facet. I need the anti-freeze for the P traps anyway. It is kind of a belt and suspenders approach but it has worked so far.
โOct-08-2015 03:11 PM
โOct-08-2015 09:56 AM
โOct-08-2015 08:17 AM
โOct-08-2015 07:35 AM
RoyB wrote:The problem with this compressor is it has no air regulator. If not careful, you could inadvertently put 150 psi pressure on your water lines and blow them apart. I wouldn't recommend that for anyone that doesn't know anything about air compressors. And it certainly won't be any use for his deck project.
For me the 12VDC TANKLESS 150PSI portable Air Compressor works the best. Most of my camping is OFF-ROAD without 120VAC PEDESTALS.
Purchased from AMAZON
I can sit my small tankless compressor on the tail gate of the truck and direct connect the 12VDC CABLES to the BATTERY BANK on the trailer. The AIR HOSE is long enough to walk around my trailer and truck tires from this position.
I use my 12VDc Compreesor for blowing out the water lines in my trailer by connecting to the CITY WATER PORT using an AIR COMPRESSOR air adapter...
Being a TANKLESS model the air compressor is slow bringing up the resulting air pressure and works ideal for me to start the air compressor and walk inside the trailer to open the sink spigots etc...
The 150PSI Air Compressor airs up all of my Truck and Trailer tires just fine...
I store this small footprint air compressor in its neat carry bag under the rear seat of my SUPER CAB truck.
Roy Ken
โOct-08-2015 06:50 AM
โOct-08-2015 05:53 AM
โOct-08-2015 05:50 AM
โOct-08-2015 04:45 AM
